Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > GR86 General Topics (2nd Gen 2022+ Toyota 86)
GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86
Old 11-22-2020, 06:39 PM   #1
drift86
Drives: GT86, 22 BRZ
Slower steering ratio?
From the press release of the 2022 BRZ:
Combined with its quick 13.5:1 steering ratio, the 2022 BRZ gives drivers a smooth, direct feel for the road and a near-instantaneous response to it.
The 2020 BRZ has a 13.1:1 steering ratio. https://www.subaru.com/vehicles/brz/...p-differential
An ultra-quick 13.1:1 steering ratio provides instantaneous response to driver input and an outstanding feel for the road.
The lower the number, the quicker the steering. So the old car has a quicker steering ratio than the new car! Wonder why they would have slowed it down as the steering on the old car was close to perfect..
drift86 is offline   Reply With Quote
The Following 2 Users Say Thank You to drift86 For This Useful Post:
alone1i (11-22-2020), Vides990 (12-05-2020)
Old 11-22-2020, 07:08 PM   #2
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
The press release never said it had a 13.5:1 steering ratio. The engine has a 13.5:1 compression ratio.
Edit, maybe your local subaru press release is different than ours. That would be really weird if they had the same compression ratio as steering ratio...
Old 11-22-2020, 07:16 PM   #3
drift86
Yes it does. https://www.subaru.com/2022-brz
The Following 3 Users Say Thank You to drift86 For This Useful Post:
alone1i (11-22-2020), Spuds (11-22-2020), Vides990 (12-05-2020)
Old 11-22-2020, 07:19 PM   #4
soundman98
ProCrastinationConsultant
soundman98's Avatar
https://www.guideautoweb.com/en/arti....5%3A1%20ratio.
straight from subaru's launch page:
Outstanding Response and Road Feel
The chassis and body of the BRZ have been reengineered for lighter weight, an even lower center of gravity, 50% increased torsional rigidity, and 60% increased front lateral rigidity. Combined with its quick 13.5:1 steering ratio, the 2022 BRZ gives drivers a smooth, direct feel for the road and a near-instantaneous response to it.
i imagine they did it because people whined about the steering being too twitchy compared to their mom's 1990 hand-me-down camry.
The Following 6 Users Say Thank You to soundman98 For This Useful Post:
alone1i (11-22-2020), daiheadjai (12-14-2020), p1l0t (11-25-2020), Spuds (11-22-2020), Tcoat (11-22-2020), Vides990 (12-05-2020)
Old 11-22-2020, 07:20 PM   #5
Spuds
The Dictater
Spuds's Avatar
Originally Posted by drift86 View Post
Ah it does on the product page, but not the press release:
https://media.subaru.com/pressreleas...s-global-debut
Old 11-22-2020, 07:28 PM   #6
Spuds
The Dictater
Spuds's Avatar
Anyway, I wonder if the 1st gen rack will be compatible with the 2nd gen for a better ratio...
The Following User Says Thank You to Spuds For This Useful Post:
soundman98 (11-22-2020)
Old 11-22-2020, 07:31 PM   #7
My wife's 17 Impreza had the 13.1 steering and it was indeed twitchy where I never felt that with the FRS. Thought maybe they went to a 13.5 on the 2020 Impreza and just parts binned the New BRZ from there. Looked it up and the new Impreza is actually now a 13.0:1. They went the other way! Odd.
It is sort of strange (not impossible still strange) that the steering ratio is listed the same as the compression ratio. Maybe one is wrong?
daiheadjai (12-14-2020), soundman98 (11-22-2020)
Old 11-22-2020, 07:32 PM   #8
Probably not worth the swap since the difference will be minimal as far as feel goes.
Spuds (11-22-2020)
Old 11-22-2020, 07:42 PM   #9
Transport3r
Drives: -
Ratio isn’t everything either. Is there any info on wether maximum steering angle is the same?
Transport3r is offline   Reply With Quote
The Following User Says Thank You to Transport3r For This Useful Post:
Tcoat (11-22-2020)
Old 11-22-2020, 07:44 PM   #10
Nothing of that sort of detail yet.
Old 12-05-2020, 01:44 PM   #11
JesseG
JesseG's Avatar
Drives: 2016 Scion FR-S
It’s not twitchy at all, it’s near perfection. And I don’t see Toyota/Subaru messing with that.
JesseG is offline   Reply With Quote
Old 12-05-2020, 09:36 PM   #12
Dake
Dake's Avatar
Even though when it came out it was the best electric steering I'd experienced to date - I assumed any twitchiness it did have came from that, not so much the ratio. That and wider tires that make it tramline a bit.
Dake is offline   Reply With Quote
Old 12-13-2020, 05:40 PM   #13
Vides990
Drives: 13 BRZ (sold) 20 BRZ TS (sold)
The ratio is different and surprisingly the marketing description is changed, they did something.
Vides990 is offline   Reply With Quote
Old 12-14-2020, 03:12 PM   #14
strat61caster
strat61caster's Avatar
Lots of things they could change to keep a similar 'feel', for instance I can imagine a hacky solution to the eps overheating/shutting down is to reduce caster to reduce the load on the electric motor which would make the car even twitchier so reduce the steering ratio to compensate. It'll lose a bit of self centering action which could make the car less driftable and caster helps in cornering keeping the tire flatter to counteract body roll so even less front grip then the old car which
ineedyourdiddly
Do sticky tires make the car feel slower? ItsReiko Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 27 07-10-2020 07:07 AM
Padldleshifting seems slower dtrop Engine, Exhaust, Transmission 10 11-07-2016 12:42 PM
FR-S Seems Slower Than Normal? jmusser96 Issues | Warranty | Recalls / TSB 18 05-31-2016 11:29 PM
How Much slower is current F1 Joakim3 Other Vehicles & General Automotive Discussions 21 12-03-2015 01:07 PM
AT officially 1 sec slower than MT at Tsukuba madfast Engine, Exhaust, Transmission 42 05-22-2012 04:24 AM
