| GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86 |
Drives: GT86, 22 BRZ
Slower steering ratio?
From the press release of the 2022 BRZ:
Combined with its quick 13.5:1 steering ratio, the 2022 BRZ gives drivers a smooth, direct feel for the road and a near-instantaneous response to it. The 2020 BRZ has a 13.1:1 steering ratio. https://www.subaru.com/vehicles/brz/...p-differential An ultra-quick 13.1:1 steering ratio provides instantaneous response to driver input and an outstanding feel for the road. The lower the number, the quicker the steering. So the old car has a quicker steering ratio than the new car! Wonder why they would have slowed it down as the steering on the old car was close to perfect.. |
#2 |
The Dictater
Drives: '13 Red Scion FRS
The press release never said it had a 13.5:1 steering ratio. The engine has a 13.5:1 compression ratio.
Edit, maybe your local subaru press release is different than ours. That would be really weird if they had the same compression ratio as steering ratio... |
#3 | |
#4 | ||
ProCrastinationConsultant
straight from subaru's launch page: https://www.subaru.com/2022-brz Quote:
i imagine they did it because people whined about the steering being too twitchy compared to their mom's 1990 hand-me-down camry.
#5 | |
The Dictater
https://media.subaru.com/pressreleas...s-global-debut |
#6 |
The Dictater
Anyway, I wonder if the 1st gen rack will be compatible with the 2nd gen for a better ratio...
| The Following User Says Thank You to Spuds For This Useful Post: | soundman98 (11-22-2020) |
#7 | |
It is sort of strange (not impossible still strange) that the steering ratio is listed the same as the compression ratio. Maybe one is wrong?
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | daiheadjai (12-14-2020), soundman98 (11-22-2020) |
#8 |
Probably not worth the swap since the difference will be minimal as far as feel goes.
| The Following User Says Thank You to Tcoat For This Useful Post: | Spuds (11-22-2020) |
#9 |
Drives: -
Ratio isn’t everything either. Is there any info on wether maximum steering angle is the same?
| The Following User Says Thank You to Transport3r For This Useful Post: | Tcoat (11-22-2020) |
#10 |
Nothing of that sort of detail yet.
#11 | |
Drives: 2016 Scion FR-S
It’s not twitchy at all, it’s near perfection. And I don’t see Toyota/Subaru messing with that. Sent from my iPhone using Tapatalk |
#12 |
Even though when it came out it was the best electric steering I'd experienced to date - I assumed any twitchiness it did have came from that, not so much the ratio. That and wider tires that make it tramline a bit.
#13 |
Drives: 13 BRZ (sold) 20 BRZ TS (sold)
#14 |
Drives: '13 FRS - STX
Lots of things they could change to keep a similar 'feel', for instance I can imagine a hacky solution to the eps overheating/shutting down is to reduce caster to reduce the load on the electric motor which would make the car even twitchier so reduce the steering ratio to compensate. It'll lose a bit of self centering action which could make the car less driftable and caster helps in cornering keeping the tire flatter to counteract body roll so even less front grip then the old car which
| Do sticky tires make the car feel slower? | ItsReiko | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 27 | 07-10-2020 08:07 AM |
| Padldleshifting seems slower | dtrop | Engine, Exhaust, Transmission | 10 | 11-07-2016 01:42 PM |
| FR-S Seems Slower Than Normal? | jmusser96 | Issues | Warranty | Recalls / TSB | 18 | 06-01-2016 12:29 AM |
| How Much slower is current F1 | Joakim3 | Other Vehicles & General Automotive Discussions | 21 | 12-03-2015 02:07 PM |
| AT officially 1 sec slower than MT at Tsukuba | madfast | Engine, Exhaust, Transmission | 42 | 05-22-2012 05:24 AM |
