Drives: 2016 Toyota 86
Worth it to swap to 2017+ intake airbox?
I am getting ready to get headers and a tune. I only want to get the tune done once so I am going to do an air filter and inlet tube at the same time.
You can get a used 2017 intake airbox and resonator for cheap now. Is it worth it at all to swap to the 2017+ airbox? As far as I know, it bolts right into the older cars. It would make sense to do it at the same time when upgrading the filter and inlet tube because it would hardly cost much more. I am not sure if there is actually any measurable gains on the dyno from the larger 2017+ airbox, though. I believe the stock intake system already flows more air than the valves can handle so power gains from changing the intake and intake manifold are minimal. It also seems 2013-2016 cars dyno about equal to 2017+ cars after header and tune. But, if it makes no difference, why would Toyota/Subaru bother? |
Drives: 2013 frs red
Because they usually change a lot to gain a little. Unless we're talking weight lol
Drives: JRSC BRZ SOLD
Its looks better and is easier to change the filters. Of all the mods mentioned it does the least.
#4 | |
Drives: 22 BRZ limited
| The Following User Says Thank You to dragoontwo For This Useful Post: | humfrz (11-18-2020) |
| best oil cooler for 2017 airbox? | jayliu.jiayu@gamil.com | Engine, Exhaust, Transmission | 54 | 06-12-2020 05:36 PM |
| 2017+ manual airbox/intake direct bolt-on for 2013-2016? | Infinity | Engine, Exhaust, Transmission | 19 | 01-07-2020 02:14 PM |
| WTB: Stock Intake Airbox | JadeBRZ | Want-To-Buy Requests | 5 | 10-22-2015 12:02 AM |
| OEM intake airbox | tech4pdx | Northwest | 5 | 12-02-2013 04:21 PM |
