Old 11-13-2020, 05:23 AM   #1
Sniepster
Drives: 2013 Toyota 86
Mishimoto cold air intake
Looking to upgrade the intake on my GT86 with a Mishimoto cold air intake. The car is my daily driver but i'm also planning on tracking it this summer, how does the pod filter fare with everyday driving? I live in a very dusty city and i'm interested on well they filter air and how easily they get clogged?
Sniepster is offline   Reply With Quote
Old 11-13-2020, 06:13 AM   #2
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
They don`t filter fine dust well. They don`t get clogged easy and they filter best when filthy.
gen3v8 is offline   Reply With Quote
Old 11-13-2020, 08:46 AM   #3
Ashikabi
Ashikabi's Avatar
Probably better off with an oiled element like a K&N
Old 11-13-2020, 09:34 AM   #4
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Save the money and keep the OEM system and replace filter with a better one.
The Following 3 Users Say Thank You to x808drifter For This Useful Post:
humfrz (11-15-2020), Tcoat (11-16-2020), The Red One (11-15-2020)
Old 11-13-2020, 05:38 PM   #5
gen3v8
gen3v8's Avatar
Drives: My18 wrxsti
That`s what it uses. Probably is K&N
Old 11-14-2020, 09:38 AM   #6
Sniepster
Yeah i already have a serviceable K&N filter that fits into the OEM airbox. I was looking to squeeze out a few more horsies by installing a complete intake system but the pod filter and the dusty environment keeps me from doing it
Old 11-14-2020, 11:52 AM   #7
churchx
churchx's Avatar
Drives: 2014 GT86
drop-in airfilter already brings out 70-80% of gains to be had from there. Aftermarket intake may net little on top of that, as stock airbox design already is rather efficient, but will cost relatively lot, making it bad by price/performance, and may introduce some illeffects, like messing MAF sensor readings and requiring to rescale them in ecu tune. If you must change out complete intake, i'd think of something like TRD's or Grimmspeed's, as they should more or less keep MAF readings same, not mess with it to artificially lean air-to-fuel ratio for extra advertisement ponies from running too lean with stock ecu tune, that are gone once you fix tune, but may put extra stresses/wear on egine from potentially more knocking.
Old 11-15-2020, 03:16 PM   #8
Sniepster
Understood. Will keep stock airbox then. Thanks!
The Following User Says Thank You to Sniepster For This Useful Post:
humfrz (11-15-2020)
Old 11-15-2020, 04:51 PM   #9
humfrz
Good plan -
Old 11-16-2020, 12:59 AM   #10
jflogerzi
jflogerzi's Avatar
Drop in filter only. Factory box is already a CAI
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
Tcoat (11-16-2020)
Old 11-16-2020, 07:32 PM   #11
SUSPECT_BRZ
SUSPECT_BRZ's Avatar
Drives: 2020 Subaru BRZ TS
From what I understand the most restrictive part on our vehicle are the catted headers. The rest is quite minimal, including the air intake and catback exhaust.
Drop-in filter and inlet tube should be a good setup for your needs. No need to spend past that. It becomes engine bay bling at that point.
SUSPECT_BRZ is offline   Reply With Quote
The Following User Says Thank You to SUSPECT_BRZ For This Useful Post:
Tcoat (11-16-2020)
Old 11-17-2020, 07:32 AM   #12
gpvecchi
gpvecchi's Avatar
I have the doubt on intake tubes, too. I think the most advantages come from closing the sound changer. I noticed the difference just with a plug.
gpvecchi is offline   Reply With Quote
Old 11-17-2020, 08:48 AM   #13
Ashikabi
Ashikabi's Avatar
At least they are cheap AF
The Following User Says Thank You to Ashikabi For This Useful Post:
gpvecchi (11-17-2020)
Old 11-17-2020, 10:09 AM   #14
churchx
churchx's Avatar
Drives: 2014 GT86
cheap AF is drop-in airfilter. Complete intake relatively way less so.
Mishimoto cold air intake (black) (SOCAL) OzzyGT86 Engine, Exhaust, Bolt-Ons 7 11-13-2021 06:36 PM
WTB: Mishimoto Cold Air Intake DAEMANO Want-To-Buy Requests 0 10-02-2015 04:29 AM
WTB: mishimoto cold air intake Sojhinn Want-To-Buy Requests 3 08-03-2015 12:10 PM
Mishimoto Cold Air Intake RELEASED! Xero-Limit Engine, Exhaust, Bolt-Ons 0 08-12-2014 08:32 AM
Mishimoto Is Giving Away a Free Cold-Air Intake For Your BRZ/FR-S/GT86! Mishimoto Announcements, Contests, Giveaways 60 07-16-2014 07:01 PM
