Old 11-09-2020, 05:25 PM   #1
Matthew_
Drives: 2014 scion frs
Coolant in cylinders
So as stated in the title, I installed an edelbrock supercharger on my frs and I accidently hooked up a coolant line on one of the vacuum lines on the intake... Does anyone have some recommendations on how to remove that coolant?
Matthew_ is offline   Reply With Quote
Old 11-09-2020, 05:37 PM   #2
Ashikabi
Ashikabi's Avatar
How much is in there? Pull your spark plugs and crank it. If there isn't much then just crank it. You can use a ratchet to turn it over, which would be safer on your valves in case there is more than expected
Old 11-09-2020, 05:46 PM   #3
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
Yes try and turn it over a few time by hand if it turns over you could use the starter afterwards. But if it hydraulic locks and won`t turn remove plugs and then use starter to clear it. It`s not the valves that will get damaged, the bearings and mainly connecting rods are at risk.
gen3v8 is offline   Reply With Quote
Old 11-09-2020, 06:06 PM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Pull plugs.
Crank while holding down the gas pedal fully, this shuts off the injectors.
Reinstall plugs.
I wouldn't try turning it over it there is anything potentially in the cylinders with the plugs in.
Old 11-09-2020, 06:22 PM   #5
Matthew_
There's alot in there I'd say... I tried to start it maybe for at least 2 minutes straight.
Old 11-09-2020, 06:24 PM   #6
Matthew_
Pull plugs.
Reinstall plugs.
I'm going to try this right now, hopefully this fixes it. Do you think I got any coolant in my oil?
Old 11-09-2020, 07:17 PM   #7
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Likely not and even if you did. It will evaporate off.
Old 11-10-2020, 06:29 PM   #8
Turdinator
Señor Member
Turdinator's Avatar
If there was a lot and you cranked it for that long you would have heard some very scary noises.
1974 TA22 Celica
2013 86 GT
Old 11-10-2020, 06:41 PM   #9
Ashikabi
Ashikabi's Avatar
Only till something broke.
Old 11-10-2020, 09:34 PM   #10
Matthew_
I just finished up today, I didn't even need to crank the car, the coolant was mostly in the supercharger, I took it off and drained the inside and then reconnected everything and it kicked on a little rough for the first couple minutes now we are fine. Thanks for the help everyone
Old 11-10-2020, 09:38 PM   #11
Ashikabi
Ashikabi's Avatar
Glad it worked out
Old 11-10-2020, 11:15 PM   #12
alphasaur
friendly
Drives: 17' 86
lol
Seek comfort in discomfort.
alphasaur is offline   Reply With Quote
Old 11-11-2020, 09:39 AM   #13
Even if mostly in the SC check the oil. If it is discoloured at all change it.
Old 11-12-2020, 12:48 AM   #14
Ultramaroon
not playing cards
Ultramaroon's Avatar
I'd take it a step further. Oil's cheap. Just change it.
How is it possible to lose coolant, if the coolant system in a car is a closed loop, ghostzfh Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 09-12-2020 01:09 AM
Coolant level dropping & Dirty coolant redwine Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 44 09-30-2018 08:37 PM
Coolant loss - Void Warranty/ Edit: coolant flush question BRZach Engine, Exhaust, Transmission 15 01-02-2016 08:21 PM
large clear plastic bottles/cylinders??!?!/ 7thgear CANADA 8 01-21-2014 08:38 AM
Difference in cylinders? Buggy51 Other Vehicles & General Automotive Discussions 6 07-02-2011 08:46 AM
