Old 11-05-2020, 08:13 PM   #1
holeeray
holeeray's Avatar
Drives: 2015 BRZ Limited
Ramps vs Jack stands
I'm planning on installing a few bushings soon and was wondering whether ramps are fine or whether I should throw it up on jack stands. Reason I ask is some installs require the suspension to be unloaded while others it doesn't make a difference.
Bushings I plan to install:
Whiteline Transmission Mount Insert
Whiteline Subframe Inserts
Perrin Rear Shift Bushing
Bone stock
holeeray is offline   Reply With Quote
Old 11-05-2020, 08:16 PM   #2
Ohio Enthusiast
Drives: 2018 BRZ
I've done all of these on jack stands.
As far as I know, you can't do the rear subframe inserts on ramps as that would load the subframe, not allowing it to drop to give clearance to put the top inserts in.
Ohio Enthusiast is online now   Reply With Quote
The Following 3 Users Say Thank You to Ohio Enthusiast For This Useful Post:
holeeray (11-05-2020), Spuds (11-05-2020), strat61caster (11-06-2020)
Old 11-05-2020, 08:21 PM   #3
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
100% jack stands.
DarkPira7e (11-05-2020), holeeray (11-05-2020)
Old 11-05-2020, 08:27 PM   #4
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Ramps are good for looking. Jackstands are good for doing
The Following 7 Users Say Thank You to DarkPira7e For This Useful Post:
holeeray (11-05-2020), norcalpb (11-05-2020), Ohio Enthusiast (11-05-2020), soundman98 (11-05-2020), Spuds (11-05-2020), Ultramaroon (11-12-2020), x808drifter (11-06-2020)
Old 11-05-2020, 09:28 PM   #5
soundman98
ProCrastinationConsultant
soundman98's Avatar
i've had ramps shift too many times while loading/unloading. way too many close calls and additional bumper scratches for no reason.
i always do maintenance on jack stands. even oil changes. they're more solid, and easier to place safely.
Spuds (11-06-2020)
Old 11-06-2020, 08:03 AM   #6
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Old school ramps, like early 90s rhino ramps, are great. Modern ones suck.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-06-2020, 07:44 PM   #7
soundman98
soundman98's Avatar
i've had 2 old sets of steel 1970-1980 vintage Sears brand ramps. i've had both sets randomly shift while driving up/down them.
and then i end up dragging the jack out anyways to get it off the one ramp that is now twisting the frame and tweaking the bumper. figure i might as well cut out the middle man and just use the jack from the beginning.
Spuds (11-06-2020)
Old 11-06-2020, 07:50 PM   #8
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
The low profile, long race ramps are great. Anything else, nah. I've had issues with anything else I've tried except on a heavy truck or something.
The Following 2 Users Say Thank You to Summerwolf For This Useful Post:
holeeray (11-08-2020), soundman98 (11-06-2020)
Old 11-07-2020, 11:37 AM   #9
gtpvette
Drives: 2015 FRS - FFR GTM
I use these cribs from race ramp. When not working on suspension they are great!!
2015 FR-S - One Day I'll Finish The Swap
gtpvette is offline   Reply With Quote
The Following 2 Users Say Thank You to gtpvette For This Useful Post:
holeeray (11-08-2020), soundman98 (11-07-2020)
Old 11-10-2020, 10:58 PM   #10
Decep
Drives: 2013 FR-S Series 10
if you use those ramps inspect the shit out of them before every use. i've seen those rhino ramps crack now and then.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
Harbor Freight Recalls Jack Stands Meant to Replace Recalled Jack Stands Tanstin User/Vendor/Sponsor Reviews, Feedback, Comments 9 07-16-2020 12:24 PM
Jack stands help cat94 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 24 02-02-2017 11:50 AM
WTB: Low profile floor jack and jack stands! lupindub Want-To-Buy Requests 2 11-26-2015 11:03 PM
FS: HF Jack $65, Ramps $45 retrosmiths Mechanical Maintenance and Tools 1 10-22-2014 02:26 PM
ramps + jack stands so26 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 04-23-2013 04:43 PM
