Old 10-27-2020, 02:10 PM   #1
slowmow
Drives: 2015 BRZ
make me less dumb - how tight is too tight for brake pads?
Hey all,
Just got some custom-made track pads from Raybestos/Porterfield - they were ground from a larger pad footprint. Some I had use a file on the backing plate edges to get them to fit in the caliper - but some are still TIGHT. With heat expansion, I'm worried that they might not move in and out as freely as they are supposed, and might drag, causing more heat, causing more sticking... etc.
Should I just drink a beer and forget it? File more off so they slide in/out more easily?
Thanks all.
slowmow is offline   Reply With Quote
Old 10-27-2020, 02:11 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
They have to slide in and out freely. If they don't, you're going to run into trouble.
DarkPira7e is online now   Reply With Quote
The Following User Says Thank You to DarkPira7e For This Useful Post:
slowmow (10-27-2020)
Old 10-27-2020, 04:29 PM   #3
With the retention clips, you should be able to get them in/out readily with just a tiny bit of tension.
What's necessitating a custom-made pad?
slowmow (10-28-2020)
Old 10-27-2020, 05:57 PM   #4
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
You want some slop and for racetrack I don't recommend retainer clips. I've had more hangups and issues with retainer clips than I care to admit before I threw them all away and life was grand.
On my CRX I used to buy pads from Porterfield for an S2000 then I would use a file to remove 1 or 2mm on the end tabs to fit in my calipers. The reason for buying the S2k pads was they were larger and got me more "meat" which translates to more heat sink.
PRO86 | WTCC | STL
The Following User Says Thank You to rice_classic For This Useful Post:
Old 11-02-2020, 12:22 AM   #5
nico_rsx
Drives: BRZ 2017 Pure Red, MT
Any disadvantage of running without the retainer clips?
I bought new OEM brake pads for the winter (came with new clips), and I had to grind/file the backplate near the tabs because they were too tight...
nico_rsx is offline   Reply With Quote
Old 11-02-2020, 12:48 AM   #6
rice_classic
Not in 16 years of W2W racing.
PRO86 | WTCC | STL
The Following 2 Users Say Thank You to rice_classic For This Useful Post:
nico_rsx (11-02-2020), slowmow (11-02-2020)
Old 11-02-2020, 02:56 PM   #7
Just noise
Old 11-02-2020, 05:41 PM   #8
Westen86
Purist
Westen86's Avatar
Drives: 2013 FRS - Hot Lava
I had to grind down the corners of the WinMax W3 pads I bought. Maybe 2-3mm on one side. You should not need tools to put in or take out pads. They sort of "click" into place. Not really, but very very little tension.
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85)
Westen86 is offline   Reply With Quote
The Following 3 Users Say Thank You to Westen86 For This Useful Post:
CSG Mike (11-02-2020), nico_rsx (11-02-2020), slowmow (11-02-2020)
Old 11-03-2020, 12:19 AM   #9
ZionsWrath
Thanks
ZionsWrath's Avatar
Take out old retaining clips. Clean any rust on the caliper bracket with a file before installing new clips. That is usually what causes this issue. But sometimes aftermarket pads are not perfect. Just make sure rust isn't the culprit first
The Following User Says Thank You to ZionsWrath For This Useful Post:
slowmow (11-03-2020)
Old 11-03-2020, 09:32 AM   #10
Westen86
Purist
Westen86's Avatar
Take out old retaining clips. Clean any rust on the caliper bracket with a [wire brush] before installing new clips. That is usually what causes this issue. But sometimes aftermarket pads are not perfect. Just make sure rust isn't the culprit first
The Following User Says Thank You to Westen86 For This Useful Post:
Clicking when turning tight Impureclient Issues | Warranty | Recalls / TSB 7 06-23-2020 05:36 AM
hand brake boot too tight akash_ Issues | Warranty | Recalls / TSB 25 11-13-2014 01:05 PM
Tight Fitting Brake Pads NightRaven Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 10-29-2014 02:13 PM
NAV unit shuts off when doing tight turns ReaperX43 Electronics | Audio | NAV | Infotainment 2 09-24-2014 09:32 PM
Fuel Lid Tight or Loose? JiB Issues | Warranty | Recalls / TSB 18 09-20-2012 12:50 PM
