Old 06-02-2014, 06:48 PM   #1
daftpunk
daftpunk's Avatar
Drives: 2013 Scion FRS
Steering wheel/dashboard getting sticky in the heat.
The steering wheel and dashboard panels of my car has recently starting becoming noticably sticky in the heat, and I am wondering if this problem is exclusive. I started noticing it on one of the hottest days so far, and thought that it might've been some residue, so I gave the entire dash a wipe with a wet rag, and then again with a very mild soapy rag - but the issue hasn't gone away. Touching the wheel at this point, even leaves a sticky residue on my hands.
Is anybody encountering this problem with their FRS/BRZ at all?
2013 Firestorm Scion FRS
2005 Civic SI Sedan- Sold
2004 Impreza WRX - Sold
1992 Civic Hatchback - Parted, RIP
daftpunk is offline   Reply With Quote
Old 06-02-2014, 07:21 PM   #2
orangeblue
Drives: Whiteout
I don't know how hot it gets where you're at, but I've never had that problem and my car regularly sits outside in 90+ degree heat (32+C for you).
Have you ever used something like Armor All on the interior? That could end up giving you a greasy/sticky residue.
orangeblue is offline   Reply With Quote
Old 06-03-2014, 12:48 AM   #3
daftpunk
daftpunk's Avatar
No, I haven't used anything more than a damp cloth on the interior prior to this happening. Today I also tried watered down vinegar solution with no luck. Some quick google research states that it's probably the plasticizers in the vinyl rising to the surface due to the heat.
I'm just wondering if there's other people out there with the same issue, to determine whether or not the dealership can do something about it, if it comes to that. It would certainly be the last resort though, since I'm worried about them either not being able to put the car back together properly, or damaging something else in the process..
Old 06-03-2014, 08:47 AM   #4
J_kennington
Drives: 2013 asphalt scion FRS
So, what was the temperature of your "hottest day". 40*? 80*? 120*?
2013 raven frs(dd/grocery getter)
1990 mitsu eclipse gsx(street/strip car)
1995 gmc 1500 4x4(off road toy)
2005 Yamaha yz250f
J_kennington is offline   Reply With Quote
Old 06-03-2014, 09:15 AM   #5
sshole
I have sticky steering wheel as well. Not sure about the dash being sticky, though. My thoughts on the steering wheel getting sticky were that I use too much hair gel and I'm somehow unable to wash off the excess from my hands, but I've tried cleaning my steering wheel with leather cleaner, a bit of dish washing soap on a damp rag, and Griot's Garage interior cleaner, all to no effect.
At this point, I'm way beyond my 3 year/36,000 mile bumper-to-bumper warranty, so if it really becomes a nuisance, I'll be forced to either replace or cover my steering wheel. I've already got my options planned out (from most to least expensive): Cusco steering wheel, JPM Coachworks cover (+thickness), or Redline Goods cover (+thickness).
sshole is offline   Reply With Quote
Old 06-03-2014, 09:19 AM   #6
daftpunk
daftpunk's Avatar
Not that hot, although Im unsure of the interior temperature at the time.
It was around 32*c (about 90*f).
Old 06-03-2014, 09:20 AM   #7
andrew20195
Drives: 2013 Subaru BRZ
If it were just the steering wheel, I'd ask if you use any kind of lotion on your hands, but I doubt you feel all over the whole dash on a regular basis.
andrew20195 is offline   Reply With Quote
Old 06-03-2014, 11:21 AM   #8
J_kennington
Then I would say you have a problem. Past 2 weeks have been 90+ and I have no problems with my wheel or dash.
2005 Yamaha yz250f
Old 06-03-2014, 12:03 PM   #9
suaveflooder
My does this as well periodically, and then just goes away. No idea why. I noticed it a couple weeks ago.
suaveflooder is offline   Reply With Quote
Old 06-03-2014, 12:40 PM   #10
daftpunk
daftpunk's Avatar
Strange =( Today`s a cooler day and my dash is no longer that sticky. The wheel, however, is still pretty tacky, and still leaves a sticky residue that`s very hard to wash off my hands. I`ll bring it up to the dealer during my lunch, then maybe try some interior cleaner. Some people have had luck using turtle wax ice interior cleaner to deal with the issue.
Old 06-03-2014, 01:09 PM   #11
J_kennington
To be honest with you. I'm betting the dealerships interior cleaner is causing it. From what I've read, our interior is actually a very pourous(spell check?) surface. And using armorall or some cleaners will penetrate it. Under heat it would make sense that anything absorbed will rise to the top.
2005 Yamaha yz250f
Old 06-03-2014, 04:14 PM   #12
daftpunk
daftpunk's Avatar
Is it just your steering wheel that's sticky or your dash as well?
Does it come and go with heating up and cooling?
I just came back from the dealer, but little input from them =(
They wiped down my wheel with some all purpose cleaner, which helped a bit, but still sticky in most areas. The dash wasn't as tacky due to it being cloudy at the moment, so they didn't see any real issues with it.
Old 06-03-2014, 04:51 PM   #13
ericmpena
ericmpena's Avatar
Drives: Subaru BRZ Limited
I thought my steering wheel was sticky once. I wiped it off with water on a soft cloth. Didn't help. I just left it alone and 2 days later it was fine.
ericmpena is offline   Reply With Quote
Old 06-03-2014, 09:18 PM   #14
suaveflooder
I've never felt my dash to be honest. It's always just the steering wheel and it comes and goes. Mostly not there, but every once in awhile, I can feel it still. I used just a damp cloth to clean my interior.
WTB: Stock steering wheel (wheel not airbag) mobybrz Interior Parts (Incl. Lighting) 2 09-11-2014 02:23 PM
scion frs steering wheel air bag and steering wheel Jhon19lopez Interior Parts (Incl. Lighting) 7 01-04-2014 06:04 PM
Swapping steering wheels with a new tC steering wheel. jonathan9573 Cosmetic Modification (Interior/Exterior/Lighting) 4 12-20-2013 11:45 PM
Different Steering Wheel?- NOT? BRZfan Cosmetic Modification (Interior/Exterior/Lighting) 10 03-07-2013 09:01 PM
That steering wheel poormans_LFA Scion FR-S / Toyota 86 GT86 General Forum 26 12-04-2011 12:16 AM
