Old 10-21-2020, 12:38 PM   #1
gt7877
Drives: turbo frs
ecutek ROM *.bin
I have wonder
If I have tuned ROM for example stage 1or 2
And in have car doesn't has ecutek license
If I flash this tune to this ecu by anyway without ecutek cable
What can happen
gt7877 is offline   Reply With Quote
Old 10-21-2020, 12:42 PM   #2
Gloonge
Drives: 2013 frs raven
If this not the right calid for the car it could just not start or it could brick the ecu.
Gloonge is offline   Reply With Quote
Old 10-21-2020, 12:44 PM   #3
gt7877
Drives: turbo frs
Leave now cid
I mean can buy this way hack ecuteck license???
Multiple maps??
Without license??
Old 10-21-2020, 02:00 PM   #4
tomm.brz
Drives: brz 2017 hksv2
you won t flash anything without a license
Old 10-21-2020, 02:00 PM   #5
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Life’s simple. You make choices and you don’t look back...
EndlessAzure is offline   Reply With Quote
The Following User Says Thank You to EndlessAzure For This Useful Post:
gt7877 (10-21-2020)
Old 10-21-2020, 02:17 PM   #6
gt7877
Drives: turbo frs
*.bin flashed to main ecu at engine bay..
Ecuteck license store at immo ecu ..
So ....
Car runs calibration data from main ecu or immo ecu??
Old 10-21-2020, 02:34 PM   #7
gt7877
Drives: turbo frs
In think I'll try it
I have 2 spare ecu and immo ecu
And stage ² ecuteck ROM
Old 10-21-2020, 02:37 PM   #8
gt7877
Drives: turbo frs
I have flasher can flash direct by obd2 this type of ecu
Denso SH72531.
Old 10-21-2020, 02:54 PM   #9
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
What about the ECUtek ROM are you hoping is advantageous for you? The great features about Ecutek are locked behind the RaceRom patch, which is applied to the ECU, not the ROM file
DarkPira7e is online now   Reply With Quote
The Following User Says Thank You to DarkPira7e For This Useful Post:
CSG Mike (10-21-2020)
Old 10-22-2020, 08:11 AM   #10
steve99
All ecutek roms are encrypted regardless of wether racerom is added. You cannpt flash ecutek roms to the ecu regardless of if racrom is added as becaise of encryption the ecu will not understand the encrypted rom.
Ecutek wil not let you flash any non stock to to ecu without adding racerom, racerom is what locks the ecu by changing the seed key access sequence.
If you try to flash an ecutek rom to an ecu with another device you will end up with a non functioning ecu.
Diring the flash process ecutek software decrypts the rom and flashes ecu, it also looks for an ecutek licience, and after its flashed rom the ecu is locked so you cannpt (easily) read oit the rom as then you would have access to the un encrypted ecutek rom with racerom.
Get a hex editor
open a stock rom (non wcutek) look at say hex 8000 address you will see the ecu calibration id like ZA1JA01G. then open and ecutek rom look at same address, rom is jist rubbish as its encrypted liked brzedit roms, they are not usable without ecutek software.
The Following 2 Users Say Thank You to steve99 For This Useful Post:
DarkPira7e (10-22-2020), gt7877 (10-23-2020)
Old 10-22-2020, 10:06 AM   #11
Kodename47
Kodename47's Avatar
Drives: UK GT86
The RaceROM patch is added into the ROM file. If the encryption wasn't there, the tables would be able to be viewed in another map editor. however as @steve99 said, the ROM files are indeed encrypted (notice how all the ROM files that come with it are #-enc.bin). I would expect that most flashing devices wouldn't recognise them, open them up in a hex editor and see the difference between an OEM/OFT ROM and and EcuTek ROM and it will become obvious.
.: Stealth 86 :.
Kodename 47 DJ:
The Following User Says Thank You to Kodename47 For This Useful Post:
gt7877 (10-23-2020)
Help with Ecutek ThisGuyTaylor Software Tuning 2 10-12-2019 02:01 PM
Have a look at this ECUtek log denso Software Tuning 14 08-16-2016 04:55 AM
FS: Ecutek ZaneRL9 Engine, Exhaust, Bolt-Ons 12 05-24-2016 07:47 PM
WTB ECUTek used xoBethxo Want-To-Buy Requests 0 04-22-2016 01:05 PM
OFT vs. Ecutek JHarperFRS Software Tuning 169 05-03-2014 12:05 AM
