Old 08-14-2016, 10:15 AM   #1
denso
Drives: 86
Have a look at this ECUtek log
Hi, please have a look at this ECUtek log file.
Your thoughts?
http://datazap.me/u/denso/2nd-gear?l...-37-38&solo=37
denso is offline   Reply With Quote
Old 08-14-2016, 07:37 PM   #2
steve99
Might help if you give a few details about mods and what your looking for.
quick look
looks like LTFT disabled or amazingly good maf scaling as its always 0
AFR is also amazingly stable at 12.17
maybe log commanded AFR as well
Old 08-15-2016, 04:31 AM   #3
Kodename47
Kodename47's Avatar
Drives: UK GT86
Stock O2 scale
.: Stealth 86 :.
Kodename 47 DJ:
Old 08-15-2016, 04:52 AM   #4
steve99
Originally Posted by Kodename47 View Post
Stock O2 scale
yep most likely, hence would be nice to see commanded afr :-)
Its still 12.17 at 1000 rpm 0% throttle load 0.2 which seems a bit odd though
other weird thing is Fuel System Status is always 1
problem with 02 sensor heater ? or not providing correct exhaust temp info.
1= Warmup not up to temp
2=Closed Loop,
4=Open Loop or de-celeration fuel cut
8=Open Loop due to system failure
Injection system status seems fine
Old 08-15-2016, 05:23 AM   #5
denso
Drives: 86
I found the problem. Closed loop map was AFR 7.91 for any reasons... I fixed that.
Can you guys tell me something about knock? IAM seems to be 1 but what about the other?
Old 08-15-2016, 06:37 AM   #6
steve99
haha that will do it , looks like someone put in E85 AFR ?
Anyway for knock you want
IAM=1
Ignition correction fine =0
Knock correction ca =0
looks like no knock in that log above
http://datazap.me/u/denso/2nd-gear?l...-38&solo=29-37
Old 08-15-2016, 07:38 AM   #7
denso
Drives: 86
Thank you Steve. What is the meaning of knock correction learn value and knock correction ca?
Can you tell me what parameters indicate knock in generall? Is it all to the IAM? If it stays at 1 my engine is healty?
Old 08-15-2016, 08:27 AM   #8
Kodename47
Kodename47's Avatar
Drives: UK GT86
Ignition Correction - Fine = FLKC
Knock Correction CA = FBKC
Those are the ones that show any knock retarded (or advanced) timing corrections.
.: Stealth 86 :.
Kodename 47 DJ:
Old 08-15-2016, 11:35 AM   #9
denso
Drives: 86
So if I see FLKC the timing is beeing pulled and if I see FBKC timing is added?
What about the IAM? Why is it stayed 1 if the ECU detects knock? This is a bit weird for me.
So Knock correction learn value ca and knock correction ca are not that parameters what Im looking for?
Thank you all!
edit: so Im looking for ignition correction - fine / FLKC and knock correction CA / FBKC.
But whats that knock correction learn value ca ? Can I ignore that parameter?
Old 08-15-2016, 03:28 PM   #10
Kodename47
Kodename47's Avatar
Drives: UK GT86
Thank you all!
FBKC will always be negative. FLKC is learnt knock retard and can only be positive when IAM is less than 1. There can be plenty of knock retard corretions without affecting the IAM, it depends on a number of factors if the IAM is going to reduce. Remember that the IAM is a multiplier for the Advance Ignition table, nothing else. Those 3 are the only ones worth logging IMO.
Ignition correction - course is the output of the Ignition Advance table and takes into account the IAM and any FLKC that is occurring.
.: Stealth 86 :.
Kodename 47 DJ:
Old 08-15-2016, 03:47 PM   #11
denso
Drives: 86
So if the FLKC and IAM are 0/1 - there is no knock? I hope that I understand this correctly.
cheers from germany
Old 08-15-2016, 04:09 PM   #12
Kodename47
Kodename47's Avatar
Drives: UK GT86
And FBKC. To put it simply, FLKC corrections only occur under certain load and RPM ranges, FBKC corrections are made when FLKC is not active.
.: Stealth 86 :.
Kodename 47 DJ:
Old 08-15-2016, 04:49 PM   #13
denso
Drives: 86
Ok, so FLKC, FBKC and IAM 0/0/1 = no knock.
But what does knock correction learn value calculated mean?
What affects the engine?
Old 08-16-2016, 12:17 AM   #14
steve99
This is the values in the Knock correction Max A table if their is no knock.
The Knock correction Learn Value CA you see in logs is
Logged Knock Correction Learn Value CA = (Value in Knock correction Max A table at same rpm/load point * IAM) + FLKC
note is possible that flkc may be positive or negtive if iam is less than one but only negative if iam is 1
You dont rearly need to look at this is you have IAM, FLKC and FBKC available its much easier just to look at those to see knock that look at Knock correction Learned CA and do lots of calculations.
explained a bit more here
http://www.ft86club.com/forums/showthread.php?t=61820
Going from OFT to ECUTEK, little help if possible nickmerronesucks Software Tuning 11 05-29-2016 03:52 AM
ECUTek TonyWA2015 Northwest 9 10-16-2015 07:00 PM
Ecutek + SCG-1 ofuts Forced Induction 2 06-12-2015 04:24 PM
WTB ECUtek. YEAHdams Want-To-Buy Requests 0 04-09-2015 11:54 PM
OFT vs. Ecutek JHarperFRS Software Tuning 169 05-03-2014 12:05 AM
