Old 10-11-2020, 08:10 PM   #1
Spankopotomous
Spankopotomous's Avatar
13 Suspension Update
I drive +15k miles a year on my stock everything 2013 FRS since buying it used with 34k on the odometer. Now approaching my 60k service interval and am wondering if a suspension update is in order.
My current commute is from Pasadena to LAX via the 210,134,110,10, 405. I love how the car handles and can feel every seam in the pavement...
Downside is THERE ARE A LOT OF SEAMS. My stock springs and struts are good, but at stock height I still scrape around LA. I hope taller/meaty tires (245/45/r17 MPSS on 17x9 +35) can give me the extra hair of ground clearance I'm looking for. If not, I hope to move towards a rally build with lift springs. (225/50/r17 MPSS on stock rims)
When updating your suspension are coilovers/shocks and springs enough or is it time to replace ALL the bushings?
AM I overthinking all of this? Maybe.
From my research I am considering these options, which is the compliant daily setup?
13 Stock springs + Bilstein B6
Chuhatsu lift springs + Bilstein B6
Full MY 20 GT86 stock suspension
(Your superior suggestion here, clearly I have no clue)
Am I wasting my money and should save up for a Cayman or GR86? LOL
Spankopotomous is offline   Reply With Quote
Old 10-12-2020, 01:09 AM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Honestly it's going to be an uphill battle.
If you really want to add more ride confort, tires wont do jack.
You'll need adjustable coilovers. With a good soft setting.
Rally settings would be ideal.
But my honest opinion, time to trade up. Go Cayman or anything sport luxury.
Old 10-12-2020, 10:12 AM   #3
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
@Racecomp Engineering is coming out with a rally-x suspension setup, that might be your best bet. For improving comfort using tires, I'd go down to a 16" wheel so that you can use taller tires without increasing your overall diameter noticeably.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
The Following User Says Thank You to Shark_Bait88 For This Useful Post:
Racecomp Engineering (10-12-2020)
Old 10-12-2020, 01:38 PM   #4
strat61caster
strat61caster's Avatar
Monotube Bilstein may be a little stiff for your commute, may not soak up the seams like you want, some people downright dislike them on other platforms. I'd be looking at Koni Yellows and use them set to soft.
ineedyourdiddly
Old 10-13-2020, 01:28 PM   #5
I'll be posting an update on our RCE Rally lift springs soon! Covid has made things sloooow but we're so close.
- Andrew
Old 10-14-2020, 01:39 AM   #6
Spankopotomous
- Andrew
Count me in, I'll be waiting patiently. What shocks/struts will they best be paired with?
Old 10-14-2020, 08:21 AM   #7
grumpysnapper
grumpysnapper's Avatar
I would definitely replace bushes, ball joints etc at the same time.
Even if its with OEM (which is absolutely fine for your usage), its not that hard or expensive to get done, and will give you a nice "reset".
grumpysnapper is offline   Reply With Quote
Old 10-14-2020, 09:03 AM   #8
Bilstein B6, but I'll be testing with OEM as well (then switching to Bilstein).
- Andrew
Rear Suspension Clunking, front suspension groaning Butterballz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 08-14-2018 07:10 PM
The suspension clunk that won't die. UPDATE: FIXED!!!! Superhatch Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 07-13-2016 10:05 PM
Squeaking / Creaking rear suspension with low ride height? Suspension pros welcome! mothespaceman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 08-14-2015 05:06 PM
Suspension update in the 86 GT Limited Ro_Ja Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 04-09-2014 05:22 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
