Meow
Drives: Focus ST mk4
Burnt seat heater bulb?
Hello again everyone,
One of the bulbs on the seat-heater switch panel burnt out on my 86.. Anyone knows whether these can be changed? Best regards, Alex |
ProCrastinationConsultant
Integral to the switch. Easier to just replace the switch
| The Following User Says Thank You to soundman98 For This Useful Post: | alex87f (10-11-2020) |
Meow
Thanks -
If anyone finds this later, part numbers are: LH: 83075FA011 RH: 83075FA001 50USD a pop on ebay. |
Drives: honda civic
Yeah you can replace it very easily.
Meow
Since paying 50 bucks to replace a bulb isn't my cup of tea, I looked at a couple of bulb replacement how-to's on Subaru forums (apparently these switches have been around since the late 90's
). https://forums.nasioc.com/forums/sho....php?t=2705743 https://www.subaruforester.org/threa...5/#post-946522 https://www.subaruoutback.org/thread...cement.195026/ (more detailed, but not exactly the right switch) These are decently comprehensive, but none of them indicates what bulb to purchase. They're 12V "grain of wheat" type bulbs, but I don't know what their intensity is, or whether several sizes exist. Anyone here knows ? |
Drives: GR Corolla
Hard to tell from those pictures, but if the whole base twists off, then I would assume it could be one of these: https://www.vleds.com/shop-bulb-numb...t4-t5-led.html
But if the bulb comes off the base, then it might be this: https://www.vleds.com/shop-bulb-numb...ed/74-6-c.html |
Meow
I've ordered a set of bulbs similar to radioshack 7219 / 2721092 (there are no radioshacks here).
They're 3mm diameter grain of wheat bulbs, 6mm long, rated at 12v / 60ma. Let's hope this works. |
Meow
I finally got around to taking care of this issue this afternoon.
Turns out it's super easy. Both seat heater switches can be taken out by removing the gear lever trim, and unclipping them through the opening. Then you just take them apart (you can do it from the upper or lower part of the switch, I found the latter easy), remove the blue rubber with the bulb, swap the bulb for a new one, and voila! ![]() ![]() Also, it's better to change both bulbs at the same time, as the standard grain of wheat bulbs found online or at retailers are a bit brighter than the stock ones. Here are the bulbs you'll need. This is literally a $2 job for both switches: https://www.radioshack.com/products/...rolamps-2-pack |
| The Following 6 Users Say Thank You to alex87f For This Useful Post: | bcj (10-25-2020), JesseG (11-05-2020), soundman98 (10-24-2020), spike021 (11-05-2020), sunami88 (10-24-2020), Ultramaroon (10-26-2020) |
Drives: FR-S 10 Series
just curious, can those incandescent grain of wheat bulbs with a LED that'll last years longer?
#10 |
yes you could, but it involves soldering, and SMD resistors.
#11 |
Meow
Also, FWIW, these are white bulbs, there's a small orange screen on the switch's "window". You'll need to remove it if you want to put a coloured bulb.
| The Following User Says Thank You to alex87f For This Useful Post: | JesseG (11-05-2020) |
#12 |
Drives: 2016 Scion FR-S
Alex I was going to be sarcastic and say “Wow look at me I’m fancy I have seat heaters!” But then you opted to replace the bulbs for $2 and totally redeemed yourself.
![]() ![]() And I also think it’s awesome that Subaru has been using the same switches for so long. That’s why our cars feel like brand new 1990’s vehicles. ![]() Sent from my iPhone using Tapatalk |
#13 | |
Drives: 2017 Subaru BRZ
Also, what bulbs did you use to replace the OEM one with? The link for the bulbs on radioshack does not work anymore. Any information is much appreciated! |
#14 | |
Meow
As for the part number, I think it was radio shack 272-1092. Good luck with the repair
| What's under the seat heater switch area?? | gtpvette | Cosmetic Modification (Interior/Exterior/Lighting) | 12 | 04-11-2019 07:33 AM |
| Dimensions for Indent w/ Seat Heater buttons | jfg5067 | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 03-14-2015 05:19 AM |
| Center Console Seat Heater Buttons | larryt1026 | Electronics | Audio | NAV | Infotainment | 15 | 07-31-2013 12:21 AM |
| BRZ Seat Heater Switch Trim Rings Availabe | zetaproducts.net | Interior Parts (Incl. Lighting) | 75 | 05-23-2013 11:21 AM |
| Seat heater temperature? | milenko11 | BRZ First-Gen (2012+) — General Topics | 29 | 09-20-2012 01:19 PM |
