Old 10-03-2020, 10:01 PM   #1
Top Gun
Top Gun's Avatar
Drives: 2013 FRS, 2015 FRS Turbo
Fuel cut/throttle cut in high boost after installing motor mounts
I installed motor mounts by jacking up the engine by the oil pan and didn't remove the header. I noticed with the engine raised, the intercooler piping was touching my APR Performance Radiator Cooling plate. It was very snug. Could a loose hose or piping cause throttle cut like that?
Pic of my engine. You can see where the APR radiator cooling plate. (Oil cooler has been installed, I just don't have a current picture.) https://imgur.com/kXfpz7u
2015 FRS - SBD 400x v3 kit with 4k miles and 8.2k miles on the car.
Top Gun is offline   Reply With Quote
short term fuel trims high at idle and and partial throttle Minidude147 Software Tuning 5 03-28-2019 05:53 AM
Fuel system questions. Boost-A-pump/stock fuel lines for engine swap Toxicmilk45 Engine, Exhaust, Transmission 4 12-14-2015 03:52 PM
High boost, e85, fuel starvation on a road course: What's everyone doing in 2015? Xero-Limit Tracking / Autocross / HPDE / Drifting 6 06-16-2015 12:45 PM
Window weld motor mounts (poor man's solid mounts) unsurety Engine, Exhaust, Transmission 8 06-05-2014 02:36 AM
FA20 Fuel lean at high boost fix cf6mech Forced Induction 15 05-20-2013 03:33 PM
