Old 10-01-2020, 10:35 AM   #1
jslack
Drives: 2017 Red subaru BRZ Limited
Best coil overs for around 1000.00
Hi group. Ok I know this is very subjective but I was seeing what people thought might be the best coil overs for around 1000.00 for mainly street use, but may run it on the track 1 time or another. Thanks.
jslack is offline   Reply With Quote
Old 10-01-2020, 11:01 AM   #2
Uncle86
Uncle86's Avatar
Drives: 2013 Fr-s
Tein flex z
Sent from my Pixel 4 XL using Tapatalk
Uncle86 is offline   Reply With Quote
Old 10-01-2020, 11:15 AM   #3
ZDan
ZDan's Avatar
Drives: '23 BRZ
In that price range you could go Bilstein B6 with either RCE Yellow or Tarmac springs for 0.8" lowering, or Swift BRZ Sport or Spec-R springs for 1.25" lowering.
I actually went Bilstein B8/Swift Spec-R, but B6s are the same with more droop travel...
The Following 2 Users Say Thank You to ZDan For This Useful Post:
Qadthane (10-01-2020), x808drifter (10-01-2020)
Old 10-01-2020, 11:22 AM   #4
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
You can get better ride/performance out of springs and dampers vs cheap "coilovers"
The Following User Says Thank You to x808drifter For This Useful Post:
ZDan (10-01-2020)
Old 10-01-2020, 11:23 AM   #5
Uncle86
Uncle86's Avatar
Drives: 2013 Fr-s
If it were a spring/shock combo +1...im a Koni Yellow fan as an alternative to bilstein
Old 10-01-2020, 11:43 AM   #6
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
The ST coilovers are the KWV1 without the branding or inox coating. I've installed KWV3s and the STs with friends, both are top quality
Old 10-01-2020, 12:48 PM   #7
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Good set of shocks, some mild lowering springs, and camber bolt for the front with SPC rear lower arms.
Everything else that is height adjustable in that price range is not worth it, especially if its primarily a street car in places where there is snow on the ground. And if you have to ask, that's even more reason to not get adjustable coilovers.
The Following User Says Thank You to mav1178 For This Useful Post:
ZDan (10-01-2020)
Old 10-01-2020, 02:11 PM   #8
ZDan
ZDan's Avatar
Drives: '23 BRZ
Agree except IMO rear lower control arms are not necessary...
Old 10-01-2020, 03:18 PM   #9
mav1178
mav1178's Avatar
I know, just added that in because 1) it all falls under $1k budget, and 2) OP wants the occasional track day.
Old 10-01-2020, 03:43 PM   #10
ZDan
ZDan's Avatar
Drives: '23 BRZ
You don't need them for track days. I'm at -2.7L/-2.9R camber in back with stock control arms, at ~1.25" lower on Swift SpecR springs. Probably more of an argument for LCAs on the street! But still IMO not necessary, particularly if lowered by less than an inch...
Old 10-01-2020, 03:50 PM   #11
Westen86
Purist
Westen86's Avatar
Drives: 2013 FRS - Hot Lava
Apexi N1 EXV
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85)
Westen86 is offline   Reply With Quote
Old 10-02-2020, 05:12 PM   #12
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Man our dollar sucks. RCE + B6 combo is going to cost me around $1700 tax in.
Old 10-02-2020, 06:03 PM   #13
Racecomp Engineering
Not sure if you've already looked, but check out www.dalesmotorsports.com for RCE parts in Canada.
- Andrew
Old 10-02-2020, 06:55 PM   #14
RToyo86
RToyo86's Avatar
- Andrew
Already have my RCE components, just need the bilsteins. pricing looks about the same for the B6. $320 per front, $236 per rear.
The Following User Says Thank You to RToyo86 For This Useful Post:
Racecomp Engineering (10-03-2020)
WTB: ST coil overs Cole Canada Classifieds 6 11-01-2016 10:55 AM
Im buying coil overs within the next 2 days i need help deciding what coil overs Anthony7515 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 06-30-2014 08:47 AM
Im buying coil overs within the next 2 days i need help deciding what coil overs to Anthony7515 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 06-27-2014 01:00 PM
Stance Coil overs or BC coil overs ? tr1x5tuh Suspension | Chassis | Brakes -- Sponsored by 949 Racing 36 11-26-2013 04:13 AM
