Old 09-24-2020, 01:58 PM   #1
MotoX16
MotoX16's Avatar
Drives: 2017 Subaru BRZ
Oil Getting Hot on Track
Hey all,
I took my car to its first track day at BIR earlier this week and had issues keeping my oil temps in check. I already have a fbm oil cooler and radiator (full mods list here: https://www.ft86club.com/forums/showthread.php?t=140753)
I was wondering what the next steps are that I could take for better oil cooling?
Ambient temp was about 80F, oil temps would rise up to about 250-260F on hot laps before I would slow down and let things cool off. I could only do about 2 hot laps before things got too hot. I also had installed an oil pressure gauge and was seeing like 30psi at redline when hot. When the oil cooled down back to around 210F I would see like 65psi at redline. I was using Castrol Edge 5w-40. Coolant temps remained in check the entire time.
The cooler sits right behind the passenger fog light and just doesnt see much air movement. The intercooler piping runs like right in front of it too so ducting from the main vent doesnt seem like a possible option. So the options I'm considering are: removing the fog light, wiring a fan to the cooler, getting a hood vent (thinking driveway labs), or going with the JR dual rad/oil cooler so it picks up air from the front.
What would you suggest?
Not my car but this is where the cooler sits
2017 Subaru BRZ PP
FBM Turbo Kit: GTX3076R - HRI FlexFuel Tune - 3" Turboback Exhaust - ID1000cc Injectors - Walbro 485 Fuel Pump - FBM Oil Pan - FBM Oil Cooler - Killer B Oil Pickup - FBM Catch Can - FBM Radiator w/Fan Shroud - Clutch Masters FX400 - Verus Clutch Fork/Pivot - IRP Shifter - Cusco Engine/Trans Mounts - RCE Yellow Springs - PS4S 245/40/17
MotoX16 is offline   Reply With Quote
Old 09-24-2020, 02:51 PM   #2
ZDan
ZDan's Avatar
Drives: '23 BRZ
FWIW my oil temp goes up to ~272F indicated on the factory gauge and holds there, every track session, whatever the ambient temp... Stock engine, no cooler.
If 30psi hot pressure at rpm has you worried, you might go to an even thicker oil for track use. Was gonna mention KillerB pickup tube but you already have that!
ZDan is online now   Reply With Quote
The Following 2 Users Say Thank You to ZDan For This Useful Post:
MotoX16 (09-24-2020), NoHaveMSG (09-24-2020)
Old 09-24-2020, 03:01 PM   #3
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
It may seem ghetto, but have you contemplated either swiss-cheesing your fog light bezel, dremeling the plastic out to give airflow, or finding bezels that have airflow pockets? I think aside changing you oil to only mildly mitigate your temps, you need to open air up into that little space.
The Following User Says Thank You to DarkPira7e For This Useful Post:
Old 09-24-2020, 03:02 PM   #4
MotoX16
MotoX16's Avatar
Should it worry me? What i've read its 10psi/1k rpm and people on here seem to think below 60psi at redline is concerning. I could go to a thicker oil...but I think if I could bring my temps down I'd be ok on my pressures
2017 Subaru BRZ PP
Old 09-24-2020, 03:05 PM   #5
MotoX16
MotoX16's Avatar
I have thought about it, and actually at the track day I tried removing the bezels. There are a few small holes behind them to let in some, although small, amounts of air. Didnt help much if it all.
I didnt have any tools with so I couldnt take the fog light itself out, seems like that would open up a nice hole to the cooler. But I'd rater just remove the foglight so I dont have cut any of the factory pieces
2017 Subaru BRZ PP
Old 09-24-2020, 03:09 PM   #6
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Strange, I am NA but I have seen 240-260F with oil cooler on a hot day, my oil pressure would still be 45-50psi at redline on 0-20.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
MotoX16 (09-24-2020), Wally86 (11-10-2020)
Old 09-24-2020, 03:11 PM   #7
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
You could cut out the flat parts of the fog light bezel to make it less noticeable.
Edit: just saw your note about not wanting to cut. removing the fog light is the next best thing.
2nd Edit: Is there enough room with the IC to make some sort of scoop that directs air from the grill to the side?
BigTuna is offline   Reply With Quote
The Following User Says Thank You to BigTuna For This Useful Post:
Old 09-24-2020, 03:34 PM   #8
MotoX16
MotoX16's Avatar
Originally Posted by solidsnake11 View Post
I would change to castrol 10-60w motor oil and see if your pressures are higher or try a different brand oil.
How many people would run an oil that gave them 30psi at redline at normal operating temperature? Now why not?
The boxer cooks itself from the exhaust being under it like a pot on a stove.
Definatly need air flow to the oil cooler.
Next track day I will try upping to a 10w-60. I'm not seeing pressures that low at normal operating temp, just once the temps get hot.
I will try removing my foglight and see if that helps get more air to the cooler. Is a hood vent necessary though? I know these engine bays are pretty sealed up and my mindset is what good does more air in do if it has no where to go
2017 Subaru BRZ PP
Old 09-24-2020, 03:36 PM   #9
MotoX16
MotoX16's Avatar
Where are you measuring pressure from? I'm grabbing it from the galley port on top of the block.
I had 0w-20 in before the track and at normal operating temp (190-200F) I would only see like 50psi at redline. Hence why I upped to 5w-40
2017 Subaru BRZ PP
Old 09-24-2020, 03:41 PM   #10
MotoX16
MotoX16's Avatar
From the front grill I dont really see a way to direct the air over to the cooler with the IC piping in the way. I might be able to make a duct from the fog light hole to the cooler though
2017 Subaru BRZ PP
The Following User Says Thank You to MotoX16 For This Useful Post:
BigTuna (09-24-2020)
Old 09-24-2020, 03:41 PM   #11
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
OEM pressure sender location on the front of the timing cover. I think I am getting some cavitation at that area so I notice odd fluctuations at high RPM, but I believe it is fairly accurate.
Old 09-24-2020, 03:52 PM   #12
ZDan
ZDan's Avatar
Drives: '23 BRZ
Should 30psi worry you, I don't know! But I *think* that 30psi should be sufficient to keep the bearings supplied with oil, and local hydrodynamic wedge should provide required film strength if you use an oil with good high-temp/high-shear characteristics.
As I think about it, if cavitation at high rpm is the issue, then going to a thicker oil might not help, might make it worse... Might stick with 5w40 or go 10w40. Or go 30 weight!
FWIW I run 5w30 synth at 272F. Dunno what my oil pressure is!
Old 09-24-2020, 04:02 PM   #13
MotoX16
MotoX16's Avatar
Alright yeah that would make sense. I plan on switching to a 5w-30 for the street, maybe I'll do some spirited driving and see if I get any better pressures
2017 Subaru BRZ PP
Old 09-24-2020, 04:17 PM   #14
MotoX16
MotoX16's Avatar
I think hood vents are to let hot air out.
I had planned on drilling holes in the wheel wells to let air through my cooler, BMW and Porsche have louvers in the wheel wells. I had my fog lights out.
If your header is not wrapped you are getting a lot of radiant heat shinning on the front cover. I'm not a fan of wrap but it would definatly help with heat. FBM headers are very good and the welds(braze) are very elastic so it should not crack with wrap.
I'm not sure an aluminum oil pan would cool or heat the oil considering how much hot air is around it.
I like the idea of vents in the wheel well. That combined with opening the fog light hole would give the air a direct in-out path.
My headers and downpipe are ceramic coated. My idea with the hood vent is it may not pull air through the oil cooler itself, but sitting right above the turbo I feel it would decrease the overall temp under the hood. Therefore lowering the oil temp
2017 Subaru BRZ PP
FS: Hawk track brake pads, DTC-30 front/HP+ rear, 90% life left, best track day combo tampaSi Brakes, Suspension, Chassis 4 05-27-2017 03:31 PM
MVP Track Time 2013 Great Lakes/Midwest Track Dates Feffman Great Lakes 5 09-07-2013 02:39 PM
GPS Track Time /Nine Lives Racing Track Day and Auto Show (Sun. 9/8) Chicago Great Lakes 0 08-13-2013 09:42 AM
Track Day: Upcoming Joey G Open Track Day for ADVANCED Drivers, Aug 20 NJMP Lightning AZP Installs NY / NJ / CT / PA 11 08-21-2012 12:31 AM
Track Day: Upcoming Joey G Open Track Day for ADVANCED Drivers, Aug 20 NJMP Lightning AZP Installs Tracking / Autocross / HPDE / Drifting 0 08-14-2012 07:46 PM
