Drives: GT86 TRD CUP
2018 Diff swap
Hi, everyone, we have a 2014 86 with the "basic basic option" used by TMG to develop their race version for europe
It's a 3.7 gear ratio and open diff. We would like to upgrade to a torsen and a shorter gear ratio, and I found this diff here for a very good price. It's from a 2018 Auto version, so the ratio is 4.1 instead of 4.3 (that would have been better) but this won't bother us too much. is there a way to confirm if this is what we are looking for (torsen and 4.1 ratio) and will it be bolt-on on our 86? thank you so much for your support Marco |
Drives: Crapcan
I believe that is the diff you are looking for. The 4.1 w/torsen that came out of my car was also a Y38.
Picture in this post when I sold it. https://www.ft86club.com/forums/show...47&postcount=1
Thanks! Is it an easy swap on a MT?
Drives: Crapcan
It is not very difficult. I had the car on jack stands and used a floor jack to support the diff during removal/assembly.
Great. I just wanted to make sure it's bolt on
Drives: Crapcan
Just be sure to inspect the new diff before install. Check that the two bushings are in good shape and that the seals for the CV axle look okay. I replaced the seals on mine before install just to be sure, though I probably didn't need to.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | Tcoat (09-25-2020) |
Got it, thanks! will install it and give you a feedback
thank you so much |
| 2017 diff swap | JOE APO | Engine, Exhaust, Transmission | 97 | 11-18-2017 09:32 PM |
| Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions | Dezoris | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-06-2017 11:54 PM |
| Swap AT Diff with MT Diff | sydious | Engine, Exhaust, Transmission | 2 | 03-17-2016 03:59 PM |
| RR Diff swap | Triumphrider | Engine, Exhaust, Transmission | 25 | 10-21-2014 09:34 PM |
| Diff swap help | wootwoot | Engine, Exhaust, Transmission | 30 | 06-10-2013 12:05 PM |
