| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Drives: 2018 Premium Black silica BRZ
How to line up banjo bolt with spiegler.
Hey how is everyone doing! I was really hoping to get some help on how to line up the banjo bolt properly to my Spiegler in order to reinstall my brake calipers.
I keep trying to tighten it but it’s fails to line up with the spiegler. Sent from my iPhone using Tapatalk |
#2 |
Drives: 22 BRZ limited
Do you mean you're having issues lining up the brake hose? I haven't looked at the hoses for this car, but isn't there an alignment pin on the hose end that fits into a slot on the caliper?
#3 |
#4 | |
The Dictater
Drives: '13 Red Scion FRS
#5 |
#6 |
The banjo head is designed so the fluid moves around the bolt, meaning bolt position is not of consequence.
| The Following 4 Users Say Thank You to ls1ac For This Useful Post: |
#7 |
ProCrastinationConsultant
the trick is to never tell the fluid!
| The Following User Says Thank You to soundman98 For This Useful Post: | pher.da.rico (09-22-2020) |
#8 |
Sorry I didn't make it back sooner, but it looks like everyone covered it. It doesn't need to be lined up. The fluid doesn't care.
| The Following User Says Thank You to dragoontwo For This Useful Post: | pher.da.rico (09-22-2020) |
| Help! Brake line leakage after steel braided line install. | ysu | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 26 | 02-09-2020 10:38 PM |
| Spiegler brake lines (front and rear) | peaches | Brakes, Suspension, Chassis | 2 | 08-06-2019 08:53 AM |
| Rotrex C38 Compressor Banjo Bolts | itsbenlol | Forced Induction | 2 | 09-04-2018 11:23 PM |
| Rear brake caliper banjo bolt size? | ChrisD | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 04-22-2016 06:51 PM |
| FS: Spiegler SS lines front and rear | ayau | Brakes, Suspension, Chassis | 2 | 12-29-2013 02:33 AM |
