Old 09-18-2020, 09:48 PM   #1
solidsnake11
Drives: brz
Dang it running out of fuel.
Censored
solidsnake11 is offline   Reply With Quote
Old 09-19-2020, 03:04 AM   #2
humfrz
Put more fuel in the car.
Old 09-19-2020, 11:32 AM   #3
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
May not be applicable, but are you using the verus fuel flap? It mostly closes the drain port in the basket to keep it from emptying when fuel is pulled by gravity enough
https://www.verus-engineering.com/sh...s-gt86-wrx-387
They specifically say "This is not a replacement for a surge tank and will not allow you to run the tank dry. " But who knows.
Old 09-19-2020, 11:46 AM   #4
soundman98
ProCrastinationConsultant
soundman98's Avatar
that looks like a massive pain to install...
Old 09-19-2020, 01:27 PM   #5
DarkPira7e
DarkPira7e's Avatar
Not really. Pull the pump hanger, which he's already a pro at, and it slides/clips in.
Old 09-19-2020, 01:45 PM   #6
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
It takes 15 minutes.
Old 09-19-2020, 01:57 PM   #7
Irace86.2.0
Originally Posted by solidsnake11 View Post
I think I am running the OE basket dry. I have a walbro F90000295 in the basket with the return ran to the factory jet pump.
Happens during a pull 1,2 and in 3rd it goes lean, running e85 and bosch 2200cc injectors on a k24
Now to solve this problem.
So is this a fuel pickup problem or a fuel delivery problem? Are you accelerating so hard that the fuel is getting moved away from the pickup when the tank is low, or are you getting this with a full tank too? If it is the former then you need to top up regularly or install a surge tank. If it is the latter then you need a better delivery system. What about running a dual pump system?
http://www.radiumauto.com/Fuel-Pump-...Z86-P1142.aspx
Old 11-22-2020, 11:24 AM   #8
solidsnake11
Drives: brz
Censored
Old 11-28-2020, 03:55 PM   #9
Clash0901
2 ugga dugga's
Clash0901's Avatar
Drives: Nike
Why is everything censored? For what it's worth on the factory tank, I have to keep it above 1/2 otherwise i get fuel slosh and fuel cut super bad sometimes mid pull if the pump isn't able to pick up enough fuel. Not really the end of the world since I know there has to be some downfall to not running a surge tank or aftermarket fuel cell.
Want to 2JZ swap your 86? Click here first!!
Clash0901 is offline   Reply With Quote
Old 11-29-2020, 07:25 PM   #10
Turdinator
Señor Member
Turdinator's Avatar
Something went down. I don't know if it was with forum users or mods but he's censored a ton of his good info. Its a real pity for the community that someone caused this but its his right to alter his posts if he wants
1974 TA22 Celica
2013 86 GT
Old 11-29-2020, 08:16 PM   #11
soundman98
soundman98's Avatar
iirc, it had something to do with some 'discussion' in the covid thread that went far off sideways. he took some post deletion as censorship, and well, the rest is history.
Old 11-29-2020, 11:03 PM   #12
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Well he certainly is making his point as I see it. Personally, I don’t like having my posts removed either. Kudos to @solidsnake11
Originally Posted by Mr.ac View Post
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
Old 11-30-2020, 05:08 PM   #13
Irace86.2.0
They do these things all the time. I’ve had posts removed.
A few weeks back I posted a well done video by Vice or Cut or something that was a chronology of every major legislation, political move or lack of move put forth by the government and the current administration prior to and since COVID as it related yo the pandemic and government agencies that relate like the CDC. Because the video had Trump as the album art, and because they said facts that weren’t flattering to Trump, like how he tried to cut funding to the CDC, the video was removed. It was probably deemed too political.
Solidsnake11’s content typically strays from facts to conspiracy theories. Some political commentary is allowed if it is generalities like saying the government is going back on lockdown, but not other things that violate the rules of the forum. I’m pretty sure what he posted violated the policy.
Old 12-01-2020, 01:14 AM   #14
solidsnake11
Drives: brz
https://www.ft86club.com/forums/show...postcount=2955
What Redline/Fuel Cut Off You Running Dezoris Forced Induction 21 06-04-2014 02:27 PM
Fuel pump running when the car is off? Target70 Scion FR-S / Toyota 86 GT86 General Forum 12 03-25-2014 06:32 PM
Electric fuel pump running with car off??? bpracer Issues | Warranty | Recalls / TSB 13 08-08-2013 10:42 AM
CEL after running out of fuel Kido1986 Issues | Warranty | Recalls / TSB 10 02-11-2013 01:34 PM
