Old 02-11-2013, 09:59 AM   #1
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
CEL after running out of fuel
Yeah, I ran out of fuel. Not sure how, should have had over a gallon remaining and I had one more mile to go to the gas station.
Refueled on the side of the road. CEL afterwards. Checked the fuel cap to ensure it's tight, drove home. Checked cap again today, still tight but still a CEL today.
Anyone else see this?
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 02-11-2013, 10:14 AM   #2
speed6sam
Drives: SWP BRZ Limited 6 Spd
Takes a few key cycles to get it to clear. You know this henry. CMON BRO =]
speed6sam is offline   Reply With Quote
Old 02-11-2013, 10:18 AM   #3
Kido1986
Dodging cones
Kido1986's Avatar
It's been 3 cycles so far. That's why I gave it a few before posting anything but I'll drive it a little more.
Never ran a running vehicle out of fuel before so this is new to me.
It's not in limp mode, pulls just as hard as normal but it sucks I have no cruise control haha
Old 02-11-2013, 10:22 AM   #4
CaptainSlow
CaptainSlow's Avatar
Disconnect the negative brake cable and press the brake for 20-30 seconds, then reconnect the battery again. That should clear the CEL. If it comes back, then you have something going on that is tripping the code still.
Ultramarine 2013 Scion FR-S 6MT
CaptainSlow is offline   Reply With Quote
Old 02-11-2013, 10:28 AM   #5
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
How did you know you had "over a gallon remaining"?
Old 02-11-2013, 11:04 AM   #6
Kido1986
Dodging cones
Kido1986's Avatar
Ive filled the car up multiple times within a mile or so of low fuel light coming and it's between 2.9 and 3 gallons remaining each time. I either used more fuel than I normally do, though it was 95% cruise control below 80mph, or the lguht came on later than normal.
I dont try to push it usually but I was on a toll road in the middle of nowhere and nearly back home.
Old 02-11-2013, 11:29 AM   #7
Boostedpro
I'm assuming that you used a gas can to refuel since you were stuck on the side of the road. It may be possible that some gas got into the breather tube on the filler neck which would have an effect on the cars evap system. This is why you are not supposed to top off new cars at the pumps. Most likely a solenoid saw some fuel in a vent line so it threw the code. Just clear it out either by the battery disconnect method or go to a local parts store like autozone and have them clear it.
Boostedpro is offline   Reply With Quote
Old 02-11-2013, 11:41 AM   #8
Eurasianman
Chief
Eurasianman's Avatar
Drives: 2013 DGM BRZ Premium 6MT
According to the manual, when your gas light comes on, you have approximately 1.8 gallons of fuel left.
Eurasianman is offline   Reply With Quote
Old 02-11-2013, 11:46 AM   #9
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
i never push my car until the last drop, i also don't wait to eat a meal when i'm about to die by starvation.
chenshuo is offline   Reply With Quote
Old 02-11-2013, 11:47 AM   #10
LavosTRD
Toyota Master Tech
Drives: Whiteout MT
Nothing to worry about IMO. They are probably Lean codes that were set when the fuel pressure dropped when you ran out of gas. Not uncommon on our cars these days. You should see the codes when a Prius runs out of gas.
LavosTRD is offline   Reply With Quote
Old 02-11-2013, 12:34 PM   #11
Kido1986
Dodging cones
Kido1986's Avatar
I dont make a habit out of it. I just really did not want to stop and pay a lot more for crap gas since I was in the boonies. I've only had it extremely low once before.
That's what I was thinking. My Bluetooth ODB adpater is broken or I'd just do it myself. Im sure got in there because the gas can I used was a serious PITA but that's what my roommate brought me.
I wasn't worried, car is running well. Just want to clear it so I can use CC again hahah (and seriously because I would never drive around with a CEL on and just ignore it)
ECUtek Flex Fuel REVOLUTION: World's First Flex Fuel Factory ECU GTR - BRZ soon! Visconti Engine, Exhaust, Transmission 356 05-20-2013 09:36 AM
Anyone running a tune? swift996 Mid-Atlantic 9 02-04-2013 10:43 AM
For those running 18x9.5 all around empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 30 11-17-2012 11:10 AM
Running 19's SocalBurt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 09-04-2012 02:45 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 04:53 PM
