Old 09-14-2020, 03:08 PM   #1
ZDan
ZDan's Avatar
Drives: '23 BRZ
Yaw sensor and braking trouble at track
Weird day at the Glen...
Got a VSC light at track. Then massive left front lockup going into 6. Had an off. With damage
Had thrown yaw rate sensor code.
Took it back out, did a few laps up to 7/10ths, was fine for a few laps, then vac light came on again and brakes went slightly nuts again, but fortunately no off.
Thinking about disconnecting ABS to prevent but looking for ideas...
WTF...
Old 09-14-2020, 03:09 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Running PD?
Old 09-14-2020, 03:15 PM   #3
kinghurl
Drives: BlueBurz
WTF...
Is this a stock brake system? Calipers, rotors, master cylinder? Did the sensor failure correspond to the locked wheel? Seems like a scary failure regardless. Really bad for a stock setup.
Sent from my SM-G955U1 using Tapatalk
kinghurl is offline   Reply With Quote
Old 09-14-2020, 04:18 PM   #4
ZDan
ZDan's Avatar
Drives: '23 BRZ
Same thing with 5 second hold or pedal dance.
Just disconnected both ABS fuses. Kinda think this should work...
Old 09-14-2020, 06:10 PM   #5
ZDan
ZDan's Avatar
Drives: '23 BRZ
Stock PP brakes with CSG Spec C2 pads in front, Winmax W5 in back. Setup had zero issues at Palmer. Practicing on Conti ECS tires today's so way undertired but again no probs at Palmer.
Tried pulling both ABS fuses but every light on dash lit up including Check Engine, revs limited to 4000ish. Re-installed small 25A ABS fuse and cleared CEL, ran some laps. No ABS so I could lock fronts, but controllable now, whereas before one front (usually left) would lock first and car would pull hard to right or STRONGLY hunt left/right.
Turbo (09-30-2020)
Old 09-14-2020, 07:09 PM   #6
Try putting ABS fuses back on, but deleting (removing) a wheel speed sensor. You'll not have ABS, but the car should drive mechanically.
JesseG (09-22-2020)
Old 09-14-2020, 07:10 PM   #7
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Since the yaw sensor is built into the ABS block, it could be a sensor that is failing causing that weird braking event and pulling one of the fuses would explain why the cars works more as intended when the ABS block is disabled.
Could also be a dirty or failing wheel speed sensor as well.
PRO86 | WTCC | STL
The Following 2 Users Say Thank You to rice_classic For This Useful Post:
CSG Mike (09-15-2020), JesseG (09-22-2020)
Old 09-14-2020, 07:11 PM   #8
rice_classic
This might be your problem - your car misses the Hoosiers and is complaining.
PRO86 | WTCC | STL
CSG Mike (09-15-2020), TunaNoCrust (10-01-2020)
Old 09-15-2020, 09:36 AM   #9
redlined600
redlined600's Avatar
Drives: Fr-s
Does your reader show chassis codes as well? Any of those pop up?
The Following User Says Thank You to redlined600 For This Useful Post:
JesseG (09-22-2020)
Old 09-15-2020, 12:49 PM   #10
ZDan
ZDan's Avatar
Drives: '23 BRZ
Normal readers didn't give any info. Guy here with laptop and Toyota software did deeper dive to find yaw sensor error.
Running fine today with big 40A ABS fuse pulled. ABS light on of course, also VSC malfunction light. Weirdly the red "BRAKE" light also on as if parking brake set, but car running great today. Do 4 laps in 14s, best lap 2:14.32, better than I expected before the event! Tires seem to need a few warm-up laps tho, 1st 4 laps were slower which doesn't bode well for great time trial (3 laps), but just glad to be runnin decent laps!
The Following 2 Users Say Thank You to ZDan For This Useful Post:
Old 09-15-2020, 01:16 PM   #11
ZDan
ZDan's Avatar
Drives: '23 BRZ
Didn't get a chance to try pulling a sensor, but seems to be working fine with 40A ABS fuse pulled...
Old 09-15-2020, 05:32 PM   #12
ZDan
ZDan's Avatar
Drives: '23 BRZ
2:14.002 in the time trial!
Old 09-15-2020, 08:23 PM   #13
rice_classic
I'm operating under the assumption that the ABS block is also responsible for brake bias. By pulling the big fuse, did you notice your front:rear bias to be any different? Easier to lock up one end vs the other than before?
PRO86 | WTCC | STL
Old 09-16-2020, 03:43 AM   #14
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Do you have any data acquisition system?
Can you log what you're getting from CAN PID 0xD0?
https://github.com/timurrrr/RaceChro...86.md#pid-0xd0
timurrrr is offline   Reply With Quote
Instability under hard braking on track, rear cross camber, road undulation, or toe? SmoothIsSlow Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 06-26-2019 02:58 AM
Had trouble engaging ABS at the track this week; how come? SmoothIsSlow Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 06-04-2019 08:54 AM
Trouble at Track, Need Help Lunatic Scion FR-S / Toyota 86 GT86 General Forum 43 07-20-2014 07:12 PM
Braking system concern after track incident SubiePig Tracking / Autocross / HPDE / Drifting 22 01-22-2014 07:35 PM
Help me track down my braking problem :( #87 Other Vehicles & General Automotive Discussions 32 09-26-2011 12:49 PM
