Old 09-08-2020, 10:22 AM   #1
j_ros94
Drives: 2017 Subaru BRZ
Transmission Fluid Recommendations
I have a boosted brz and very rare cases I can't shift to any gears from a stop. I was looking to do an tranny fluid change and see if that works. What would you guys recommend?
Thanks
Sent from my SM-G960W using Tapatalk
j_ros94 is offline   Reply With Quote
Old 09-08-2020, 11:36 AM   #2
humfrz
Thanks
I doubt the transmission fluid (unless it is low) is causing that situation.
I'd suggest you first check the fluid level.
If you're bound and determined to change brands of oil, a quick forum search would yield all kinds of peoples choices.
If it were me, for average driving, I'd stick with the OEM stuff.
Old 09-10-2020, 05:44 PM   #3
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Did you try bleeding/adjusting the clutch yet? I would try that before looking at transmission oil.
Old 09-10-2020, 05:58 PM   #4
TommyW
TommyW's Avatar
Drives: '13 Whiteout
Motul however you need to see what the problem is
Old 09-18-2020, 03:52 AM   #5
wil5bart
Drives: '16 BRZ
Aside from Motul, Redline is a good choice.
wil5bart is offline   Reply With Quote
Old 09-18-2020, 11:40 AM   #6
Westen86
Purist
Westen86's Avatar
Drives: 2013 FRS - Hot Lava
Pentosin MTF2
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85)
Westen86 is offline   Reply With Quote
Old 10-03-2020, 03:54 PM   #7
ilham sarwar
Drives: Toyota Gt86 2012
seeking for help
Hello everyone! I m new here. I would really appreciate to know how to change atf in my 2014 gt86 as I m looking forward to changing it. Would really appreciate an in depth procedure. Tia😊
ilham sarwar is offline   Reply With Quote
Old 10-03-2020, 04:47 PM   #8
Ultramaroon
not playing cards
Ultramaroon's Avatar
Originally Posted by ilham sarwar View Post
Hello everyone! I m new here. I would really appreciate to know how to change atf in my 2014 gt86 as I m looking forward to changing it. Would really appreciate an in depth procedure. Tia��
Welcome!
TX6A AUTOMATIC TRANSMISSION / TRANSAXLE: AUTOMATIC TRANSMISSION FLUID: REPLACEMENT; 2014 MY FR-S [07/2013 - ]
Not my site. See more in signature line.
Old 10-04-2020, 03:04 AM   #9
ilham sarwar
I can't find the drain plug. Can you or anyone here locate me the drain plug for the ATF
Old 10-04-2020, 02:47 PM   #10
Ultramaroon
not playing cards
I mean no insult. If you are unable to find the drain plug, it's probably best that you have a professional do the job for you.
Old 10-04-2020, 03:34 PM   #11
Spuds
The Dictater
Spuds's Avatar
So out of curiosity, it looks like *2 in the first image is the overflow plug, is there a separate drain plug on the pan somewhere? I have an MT, otherwise I'd look next time I'm under there.
Old 10-04-2020, 04:12 PM   #12
Ultramaroon
not playing cards
DIY: Automatic Transmission Fluid Change
Yeah. The views in the manual are not clear but they are accurate.
Old 10-05-2020, 12:45 AM   #13
ItsReiko
ItsReiko's Avatar
Drives: 2017 subaru brz
Out of curiosity, since almost no one changes the transmission fluid with OEM fluid (according to the forums), and Subaru OEM Gear Oil is GL5 while the transmission recommends GL3/4, does that mean Subaru themselves do not make an OEM fluid suitable for our transmissions?
I really enjoy the oem shift feel but really can't make a decision if I want to buy their High Performance Gear Oil after reading too many forum posts that it will deteriorate my transmission because of the GL5 spec. Please enlighten me lol.
I wonder what was put in from the factory..
ItsReiko is offline   Reply With Quote
Old 10-05-2020, 10:10 AM   #14
Westen86
Purist
Westen86's Avatar
transmission fluid John27 Scion FR-S / Toyota 86 GT86 General Forum 7 04-25-2017 08:14 PM
Transmission Fluid euthqt Issues | Warranty | Recalls / TSB 8 04-14-2016 08:20 AM
6MT Transmission Fluid Recommendations Ferrari Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 97 04-30-2015 05:06 AM
Trans/diff fluid recommendations: Motul Gear 300, Extra-S, or.. B-R-Z Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 07-03-2014 08:06 PM
What transmission fluid are you using? Chillz Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 25 04-06-2013 10:45 PM
