Old 09-05-2020, 10:13 PM   #1
El Solid
Drives: 2013 Scion FRS
FRS CLUTCH SWAP ISSUE
I swapped my clutch on my Scion FRS 2013 and everything went on fine and seems to be working after it was put back together and then the issue arose when getting into gear. The first gear makes the car go into reverse and it won't go into second gear but will go into 3,4,5,6. The car is not fully put back together for this reason but does anyone know how to make it so that the car will register first and second gear cause the reverse lever isn't being used and it won't allow it to go into first or second.
THANKS for the help
El Solid is offline   Reply With Quote
Old 09-06-2020, 04:47 AM   #2
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
THANKS for the help
You're missing the lockout plate
EndlessAzure is offline   Reply With Quote
The Following User Says Thank You to EndlessAzure For This Useful Post:
Spuds (09-06-2020)
Old 09-06-2020, 11:44 AM   #3
El Solid
I have that plate and thought initially that was the issue but it wasn’t cause even with the plate there the first gear makes the car go reverse, which is why I’m really confused.
Old 09-06-2020, 02:17 PM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
It is not possible for 1st to make the car go into reverse. You need to adjust the plate.
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post:
DarkPira7e (09-06-2020), p1l0t (09-07-2020), Spuds (09-06-2020)
Old 09-06-2020, 03:33 PM   #5
El Solid
It was the plate I guess I just didn't adjust it correctly even though I moved it multiple times. Thanks for help!!!
The Following 2 Users Say Thank You to El Solid For This Useful Post:
#clutch, #frs, #problem
Swap issue: No starter trigger Shit Luck Engine Swaps 26 11-20-2019 09:33 AM
Clutch winning and idle issue with clutch zackegle Issues | Warranty | Recalls / TSB 13 12-05-2016 10:38 AM
HELP!!!! CLUTCH ISSUE mattaubel Engine, Exhaust, Transmission 3 07-27-2016 03:03 AM
Clutch engagement issue. Possible clutch cylinders upgrade? wu_dot_com Engine, Exhaust, Transmission 42 04-05-2016 12:11 PM
clutch issue yurgirlishot Issues | Warranty | Recalls / TSB 14 11-15-2013 04:20 PM
