Old 08-29-2020, 07:11 PM   #1
airdaddy
Drives: WRB BRZ
Center exhaust pipe damaged, looking for cheap alternatives
I wish I inspected the car before I purchased it, because I noticed a leak after I jumped a curb, then put it on a lift and the center exhaust is bent (you can kind of see the kink) from the previous owner.
Looking for cheap fix
Sent from my SM-N960W using Tapatalk
airdaddy is offline   Reply With Quote
Old 08-29-2020, 07:56 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Cheap fix = exhaust shop.
Or find a used stock nearby, people practically give them away.
DarkPira7e is online now   Reply With Quote
Old 08-29-2020, 08:25 PM   #3
Joveen
Joveen's Avatar
Drives: Bone stock
I'll give you mine for a price
Sent from my SM-N960U using Tapatalk
Joveen is offline   Reply With Quote
Old 08-30-2020, 05:41 AM   #4
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Don't worry about it if it's not leaking.
It's a common place for exhausts to become flat, especially if you plan to lower the car in the future. It's the lowest point on the car where the exhaust will cross over, and had a good chance of smacking the ground.
If it has a hole where it's flatted, get an exhaust shop to weld it closed. If you really care, people sell whole used stock exhaust systems for $50 to $150.
EndlessAzure is offline   Reply With Quote
Old 08-30-2020, 04:36 PM   #5
jflogerzi
jflogerzi's Avatar
If your in socal I will give it to your for lunch
2013 Series 10 FRS #553
Old 08-30-2020, 05:53 PM   #6
humfrz
If it's not leaking, don't worry about it.
There, is that cheap enough for ya? -
Old 08-31-2020, 12:01 AM   #7
Turdinator
Señor Member
Turdinator's Avatar
Personally I wouldn't care on a stock twin. Simple fix would be buy a second hand stock axle back from someone "upgrading" their exhaust.
1974 TA22 Celica
2013 86 GT
Alternatives to the TRD exhaust rphello101 Engine, Exhaust, Transmission 8 11-04-2018 12:36 PM
Cheap UEL alternatives? haavardnk Engine, Exhaust, Transmission 34 10-05-2016 09:56 AM
WTB Cheap Catless front pipe/test pipe JarredH Want-To-Buy Requests 0 05-26-2016 12:08 PM
Opensource live logging or cheap alternatives dave- Software Tuning 0 01-18-2016 04:06 AM
Agency Power Front/Over pipe (Combo pipe) - Cheap! seven Engine, Exhaust, Bolt-Ons 12 03-09-2013 01:40 AM
