Old 08-27-2020, 07:49 PM   #1
matapexxxX
Drives: 2013 Scion Fr-s
MD Emissions with UEL catless headers
I'm looking to get a UEL catless headers, but I'm concern that it won't pass the emissions test, Anybody has experience with this topic? would a tune also mess with the emissions test?
matapexxxX is offline   Reply With Quote
Old 08-31-2020, 10:15 AM   #2
rns294
Drives: 13 BRZ
It's based on OBD so if you remove the header cat, there will be a CEL from the O2 sensor. You can tune the car in such a way that this goes away and throws a "not ready" signal, which in VA you are allowed 1 and can still pass the test. I think this will be the case for MD but I can't verify.
Additionally, as long as you don't remove the front pipe cat, you'll likely pass a visual inspection since the header cat is hidden under a skid plate. Most people aren't going to bother lifting the car and removing that or they won't even know there should be a second cat there.
I would assume you'll probably fail an emissions sniffer test like the VA rapidpass ones.
rns294 is offline   Reply With Quote
Old 02-27-2021, 08:43 PM   #3
ybotspawn
ybotspawn's Avatar
Drives: 13 Subaru BRZ
You’ll pass as long as there’s no cel. Just find a decent tuner
ybotspawn is offline   Reply With Quote
Old 04-27-2021, 08:43 AM   #4
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
Same question here.
I just decided to change my registration from NJ to MD.
I got catless header and front pipe. The resonator on my HKS front pipe looks similar to a cat which is kinda tricky in a visual inspection. I have passed the inspection in NJ and PA with this setup and 1 signal ignored because not catless header (CEL has been tuned off).
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
Old 04-27-2021, 10:32 AM   #5
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
I've always passed as long as I have no CEL (including long term codes that aren't throwing the light atm)
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
emissions, headers, uel header
Catless Emissions? Howaitoguru Engine, Exhaust, Transmission 10 07-09-2019 07:16 PM
Headers and Portland emissions Sergeb96 Northwest 20 02-17-2018 10:55 AM
Headers and emissions question for Sydneysiders Ginosaur AUSTRALIA 18 04-20-2016 06:23 AM
Frontpipe catless/hfc and emissions, sound level... steveholt Engine, Exhaust, Transmission 20 04-05-2015 12:11 AM
Cat-less headers and passing emissions Aaron_blatherwick Engine, Exhaust, Transmission 12 06-29-2013 12:53 PM
