Northwest AK, ID, OR, WA
Old 02-16-2018, 04:01 PM   #1
Sergeb96
Sergeb96's Avatar
Drives: 2013 Subaru BRZ Premium MT
Headers and Portland emissions
Hi, couldn’t find a specific answer so figured some of you guys might know.
I plan to buy tomei uel headers in the coming months to pair with my n1 catback.
My deq is next March, and I’m wondering will I pass emissions with this setup, or will I have to put the stock headers back on when I go in? Thanks in advance.
Sergeb96 is offline   Reply With Quote
Old 02-16-2018, 04:51 PM   #2
Imrac
Drives: 13 SWP BRZ Prem
It will be removing your primary cat, as such you will get a check engine light (FAIL) unless you tune it out (Removing the code) .
If you plan on switching back to your stock header, make sure you drive your car a while with it on if you clear codes or reset the ECU. You will need to make sure all the readiness checks are good, otherwise they may tell you to come back later.
I don't know if Oregon does a visual inspection or not.
Edit: Also, with the N1, it will be VERY loud. so be prepared for that...
JDL UEL Headers, Nameless Res&Cat Over&Front, Invidia Q300 Catback, AVO Dry Panel Filter, Custom ECUTek Tune by DriftOffice
191WHP/151 ft-lb on 92
Imrac is offline   Reply With Quote
The Following 2 Users Say Thank You to Imrac For This Useful Post:
15limited (02-16-2018), Sergeb96 (02-16-2018)
Old 02-16-2018, 05:25 PM   #3
AnotherDude000
Drives: 2022 GR86 Neptune Blue!
No visual inspection in Oregon, so you'll be ok. If you do one of the following:
It depends. If you use a spacer for the O2 sensor and it WORKS, and you have no CEL, then you'll be fine. Spacers are 50/50. Otherwise, if it doesn't work and you get a CEL, you'll either need to tune it or swap back to OEM for the DEQ test.
When you switch back to OEM, you'll need to drive it probably 25-30 miles for the ECU to be ready for the OBDII.
I would recommend a tune.
AnotherDude000 is offline   Reply With Quote
The Following User Says Thank You to AnotherDude000 For This Useful Post:
Old 02-16-2018, 05:27 PM   #4
Sergeb96
Sergeb96's Avatar
I’m going to be tuning 100% with a OFT.
Old 02-16-2018, 05:36 PM   #5
AnotherDude000
You'll be fine then. OFT will get rid of CEL and pass DEQ.
The Following 2 Users Say Thank You to AnotherDude000 For This Useful Post:
LeonardoDaVinny (01-06-2019), Sergeb96 (02-16-2018)
Old 02-16-2018, 05:36 PM   #6
Sergeb96
Sergeb96's Avatar
My friend sold me the N1 when I got the car, so that’s what I’m working with. I was told it’s loud, hopefully it’s not gonna make my ears ring...
Thanks for the insight.
Old 02-16-2018, 05:38 PM   #7
Sergeb96
Sergeb96's Avatar
Perfect. I was worried I had to remove headers and put stock tune on. Thanks so much for the help. I can rest easy now.
Old 02-16-2018, 05:44 PM   #8
Sergeb96
Sergeb96's Avatar
Hey I also had one more question. On ft86speedfactory on the headers page it also shows options to buy grimmspeed gasket and o2 sensor. Should I buy any of those too?
Old 02-16-2018, 05:58 PM   #9
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Expreme Engrish
Old 02-16-2018, 05:59 PM   #10
Sergeb96
Sergeb96's Avatar
Expreme Engrish
I beg your pardon?
Old 02-16-2018, 06:00 PM   #11
AnotherDude000
The Gasket is to keep a good seal on the header so it won't leak. Grimmspeed ones are a little thicker so it seals better but I didn't need one for my Borla. I went to the local Subaru dealer and picked up a new OEM one for half that price.
You don't need the O2 spacer because you'll be running OFT, but until you get the OFT you'll probably be getting a CEL.
Old 02-16-2018, 06:01 PM   #12
Sergeb96
Sergeb96's Avatar
When I purchase, I’m going to buy both the header and tablet together. Thanks for the heads up on the gasket. Appreciate your help.
Old 02-16-2018, 06:56 PM   #13
HSUBLU
Drives: 2017 BRZ WR Blue
You might be able to find some good deals on folks locally that would be selling slightly used UEL headers, if you're willing to wait and keep your eyes open.
HSUBLU is offline   Reply With Quote
Old 02-16-2018, 07:53 PM   #14
Omi Ham-Sandwich
☆ミ
Omi Ham-Sandwich's Avatar
Drives: FR-S 2016 Ultramarine
It will... b/c I have it... w/ the Tomei UEL.
Omi Ham-Sandwich is offline   Reply With Quote
OFT+OFH emissions Texas2016Frs Software Tuning 15 10-09-2016 02:35 AM
Headers and emissions question for Sydneysiders Ginosaur AUSTRALIA 18 04-20-2016 07:23 AM
Emissions with aftermarket headers in DMV area ap5512 Mid-Atlantic 11 12-30-2014 07:19 PM
Emissions - MD TheseColorsDontRun Mid-Atlantic 6 08-23-2013 07:06 PM
Cat-less headers and passing emissions Aaron_blatherwick Engine, Exhaust, Transmission 12 06-29-2013 01:53 PM
