Old 08-17-2020, 12:35 PM   #1
airrick
Drives: TRD R.S. 1.0 FRS
Wastegate pivot leaking
Hello,
I have a Works turbo stage 2 on my car, about 2k miles so far. I found a leak at the wastegate pivot. I did some researching to try to fix this. I adjusted the rod so there was no play but seems to have a little play. Not sure if this is normal or not. The leaking happens without any revs, i start the car up and wait a few seconds then leaks.
Am I gonna have to replace the hot side of the turbo? the pic below is the leaking it does only after like a minute or two or leaving the car on from cold start.
airrick is offline   Reply With Quote
Old 08-17-2020, 12:37 PM   #2
airrick
Videos of the leaks while car is on.
just seeing how much play i have.
Old 08-17-2020, 01:47 PM   #3
sroby
Drives: 2015 Firestorm 08/05/15
If it’s knew to you with only 2,000 miles I would think works would warranty or at least inspect and repair, have you reached out to them ?
sroby is offline   Reply With Quote
Old 08-17-2020, 02:18 PM   #4
airrick
oh yea, i forgot to mention. Its a used one. i got it from a dude that said it was like 100 miles before his rod made a hole in his block. Yea i know thats not very good to hear. When i bought the turbo kit, everything was very new. There wasn't any carb/dirt/whatever in the exhaust pipes, but who knows what how long he did drive it though. I'm thinking his recall work had something to do with the engine failure.
Anyways, I have tried to call works, left them a voicemail and sent them an email. Will most likely call them again later and try to make it over to them. I just wanted to see if anyone here with more turbo experience would know what to do or went through something like this.
Googling this issue, apparently there is a bushing in the flapper. I'm thinking it's gone bad.
Old 08-17-2020, 07:15 PM   #5
sroby
Waste gate shaft play
Maybe call Jon Bond of Jon Bond Performance. He is all knowing of everything supercharger. I know it’s a turbo. But I’ll bet possibly you could send him the unit and he can make the bushing. I had issues with the same type of situation with my sprintex supercharger. They have a know leak at the bypass valve shaft a manufacturer defect. He created an oring shaft repair by creating a and making a bronze bushing. He is that great. I would reach out to him mention you talked to me Steve Roby. I’m sure he can get it squared away. Hope this helps ��
The Following User Says Thank You to sroby For This Useful Post:
airrick (08-17-2020)
Old 08-17-2020, 11:21 PM   #6
airrick
I'll most probably just get works to help me out. They're only about an hour away from me.
but if anything this will be a last resort.
appreciate the advise!
Old 08-18-2020, 12:24 AM   #7
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Is it leading to a boost leak or messing with the o2 sensor messing up air/fuel? If not then maybe you can live with it?
Old 08-18-2020, 08:04 AM   #8
Grady
Grady's Avatar
Hard to tell but that does not look to bad. It has to be loose when it is cold, remember when it is hot everything is a different size. If you are not having any issues I would not worry about it.
The Following User Says Thank You to Grady For This Useful Post:
airrick (08-18-2020)
Old 08-18-2020, 03:42 PM   #9
airrick
Oh thats right, forgot about that. I’m not have issues with driving or anything. Just being caution before it turns into a big problem.
I dont think its missing with the A/F and boost seems to be holding fine. Most likely ill live with it since a new turbine housing is like $500 lol. Just wanna err on the side of caution before this tiny problem becomes a way bigger one.
Sorry for for noob question but how would i know if its messing with the o2 sensor? The car would be driving rich or rough right? I know my tune is on the rich side. (Tuner intended this)
I guess i’ll know something is up when my turbo blanket goes bad. Haha its soaking up the exhaust gas/fluid.
REVIEW | Pivot Dual Gauge DXW-W/DXW-R mav1178 Cosmetic Modification (Interior/Exterior/Lighting) 15 11-17-2019 06:54 PM
Gauging interest: Pivot Dual Gauge Pro DPW (formerly Pivot Dual Gauge DXW) mav1178 Cosmetic Modification (Interior/Exterior/Lighting) 3 08-23-2017 12:32 PM
Pivot dual gauge ANREX Cosmetic Modification (Interior/Exterior/Lighting) 39 03-01-2014 06:19 PM
Pivot 3-Drive-BLP Install + Review Argento_FR-S Engine, Exhaust, Transmission 14 09-05-2013 10:41 PM
FS: Pivot MegaRaizin Voltage Stabilizer JPxM0Dz Canada Classifieds 0 07-29-2013 08:13 PM
