Old 08-14-2020, 04:35 PM   #1
fatboydean
Drives: 2016 BRZ Hikari
Trying to understand why OFT maps can get rip of torque dip
Hi all,
I am trying to find out the reason why the OFT OTS maps can help get rid of the torque dip. I did a comparison between stock and OFT stage 2 maps on open loop fueling and base timing.
Since I am a noob I could not understand the principle behind it.
For fueling the stg2 maps runs richer on mid engine load and leaner on high engine load. From my understanding lean mean more torque, but more likely to have knock.
For base timing, same as stock!
Am I looking at the right direction? I did try to search 'torque dip' in this forum but not much related info.
Please help I just wish to understand things. Attached file is what I copied from both maps.
fatboydean is offline   Reply With Quote
Old 08-14-2020, 06:44 PM   #2
gt7877
Drives: turbo frs
Try to compare oft tune with WAYNO ROMs
https://www.ft86club.com/forums/showthread.php?t=127695
gt7877 is offline   Reply With Quote
Old 08-14-2020, 06:46 PM   #3
Kodename47
Kodename47's Avatar
Drives: UK GT86
Cam timing
.: Stealth 86 :.
Kodename 47 DJ:
The Following 2 Users Say Thank You to Kodename47 For This Useful Post:
Spuds (08-14-2020), steve99 (08-15-2020)
Old 08-14-2020, 08:36 PM   #4
fatboydean
Thanks!!
Old 08-14-2020, 08:37 PM   #5
fatboydean
But where to get WAYNO roms?
Old 08-14-2020, 08:48 PM   #6
churchx
churchx's Avatar
Drives: 2014 GT86
click
The Following User Says Thank You to churchx For This Useful Post:
gt7877 (08-15-2020)
Old 08-17-2020, 06:36 PM   #7
Flukester
Flukester's Avatar
Drives: 2019 BRZ - Raiu
+1 for Wayno ROMs.
See link posted by @churchx in the message above. Lots of good information on Wayno's site. Great set of files provided with the ROMs as well (definitions, etc).
Flukester is offline   Reply With Quote
Old 08-18-2020, 03:29 PM   #8
86TOYO2k17
Drives: 2017 toyota 86
OFT tunes don’t eliminate the dip, stage 1 slightly reduces it. Stage 2 is for aftermarket header which now the header further reduces dip but still not eliminates it. stage 2+ is for aftermarket catless header which again further reduces dip because no cat but still not 100% gone (some headers do some don’t) stage 2+ w/ E85 will completely eliminate the dip (some will even have a mound instead of dip)
Old 08-18-2020, 05:05 PM   #9
LancePower
Drives: 2020 BRZ tS
Do these Wayno ROMs reduce the dip further than the OFT Tunes?
LancePower is online now   Reply With Quote
Old 08-19-2020, 03:06 AM   #10
churchx
churchx's Avatar
Drives: 2014 GT86
That's not main goal of wayno's (or OFT) tunes nor i think they can do much about it. Maybe reduce rpm range at which it is, maybe reduce a bit drop, but there are limits to what just ecu tune can do. Mostly to get rid of torque dip some of aftermarket headers can (usually UEL, also some EL ones, mostly catless). Forced induction also fills it.
But! Imho that dip is greatly overcriticized as some major issue and end of the world. When one daily drives with traffic flow mostly one is at rpm-s below it. On track one anyway drives in rpm powerband above it. And even if one is lazy to shift during daily driving, it's not as if car doesn't accelerate during dip at all, just at a bit slower rate. Really don't get why all the fuss about it. Similar dip somewhere in lower-mid rpms is there for many other cars .. but somehow i don't notice other car owners making such big deal of it as many twins owners do. Heck, until i read about that dip in forums mentioned oh so many times, i didn't consciously noticed it myself, just drove car.
Ohio Enthusiast (08-20-2020)
Old 08-19-2020, 03:20 AM   #11
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Main reason is that nowadays we have so many cars with small turbos and better torque curves in the mid rev range. In contrast, a NA engine needs to be revved to go fast. If the owners try to accelerate against these cars and they are lazy to downshift, then they see their car to not accelerate that much. The easy thing is to blame the torque dip "monster", instead of trying to understand the nature of a NA engine.
Old 08-19-2020, 03:44 AM   #12
churchx
churchx's Avatar
Drives: 2014 GT86
I wouldn't associate that with NA in general. After all, especially US traditionally had loads of big displacement NA engines with plentiful power & torque even down low. Rather in small displacement high-rpm high-efficiency engines (traditionally japanese made) that are very efficient yet need to be revved high, if one is to generalize.
Still, dip in honda-s is "vtec kicked in yo", no complains in eg. porsche caymans, or lexus is350, or WRX or many other cars/engines with characteristic dip .. yes, probably it's human perception factor, when one is spoiled with more and more common forced induction.
My advise would be to ignore it, as it's not as big of an issue as some make it as one, especially if one actually uses gearbox as intended. If anything, imho FA20 has unusually high torque before dip for 2lr NA engine, and at dip "normal" output .
Old 08-20-2020, 12:20 AM   #13
Danny318
Drives: 2019 BRZ
This is a good question!
Danny318 is offline   Reply With Quote
Help me understand what Im looking at on the OFT Last Lemming Alive Software Tuning 5 01-27-2018 10:53 AM
Help me understand the internal WG on EFR bakerr6 Forced Induction 2 01-12-2015 06:33 PM
OTS 2.05 Stage 2 UEL 91 Map - Need help to understand this log ssyed Software Tuning 36 08-26-2014 02:33 AM
Help me understand the BRZ/FRS engine! BRZnut Engine, Exhaust, Transmission 6 12-14-2012 09:39 PM
What I just don't understand... Liquidcell Scion FR-S / Toyota 86 GT86 General Forum 35 08-30-2012 09:38 AM
