Old 08-13-2020, 01:36 PM   #1
WORKS
WORKS's Avatar
Drives: WORKS CARB Legal Turbo BRZ
First CARB Compliant Turbo Kit for 2017-2019 BRZ & 86!
Hello FT86 Club friends!
We’ve been working tirelessly on this project for some time now and are excited to announce that the WORKS BRZ / FR-S / 86 Turbo Kit is now CARB Compliant for 2017-2019 model years. Joining our 2013-2016 Compliant kit, That makes it the first and only street-legal turbo solution for the chassis on California roads!
We’ve opened up a pre-order on our website for those of you who have been waiting for another CARB Compliant FI option to hit the market.
Feel free to check it out for more information:
https://store.worksmotorsports.com/W...p/142.214c.htm
WORKS is offline   Reply With Quote
Old 08-13-2020, 02:10 PM   #2
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
I see there is a small shield but any issues or concerns about the turbo heat being that close to the battery?
Clueless
YamahaR86 is offline   Reply With Quote
Old 08-13-2020, 03:00 PM   #3
WORKS
WORKS's Avatar
For extra peace of mind and some engine bay bling, DEI makes some awesome gold reflective heat tape , but it's really not necessary. We've monitored battery surface temperatures after extended track sessions and stress testing and found them to be a non-issue when using the provided heatsheild.
- WORKS Team
Old 08-13-2020, 04:00 PM   #4
Jo0
Drives: '17 CWP Limited w/ PP
Is it safe to assume that most/all aftermarket headers that retain the OEM overpipe would work in conjunction with this kit?
Jo0 is offline   Reply With Quote
Old 08-13-2020, 04:53 PM   #5
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
A light weight (smaller) battery would probably allow more gap between the turbo and battery, and a turbo blanket is a good idea in general.
Old 08-13-2020, 04:54 PM   #6
Irace86.2.0
99.999% sure yes.
Old 08-13-2020, 07:55 PM   #7
WORKS
WORKS's Avatar
Great ideas/input for avid track enthusiasts!
The original, OEM battery on our 2014 BRZ test vehicle is finally starting to show signs that it might be time for a replacement after 7 years of use (won't hold a charge if not driven for a few weeks). We installed the kit over 25k miles ago, and have participated in countless track days, challenges, and drift events. Most batteries are recommended to be replaced after 4-6 years. Not bad!
99.999% sure yes.
Correct! The kit takes the place of the factory overpipe for the up and down-pipes. We have found that there is minor variation in OEM exhaust manifold fitment, and have built in a specific tolerance in the up-pipe to ensure proper fitment.
So as long as the fitment of your aftermarket header is within OEM standards, it will physically fit with the kit, and further gains can be had.
However; we do have to make it very clear that installing an aftermarket header that is not smog legal will compromise your vehicles compliance.
WORKS Stage 2 Turbo Kit - Now CARB Compliant/SMOG Legal WORKS Forced Induction 415 10-16-2021 05:55 PM
WORKS Stage 2 Turbo Kit - Official Released! - Now CARB Compliant/SMOG Legal WORKS Forced Induction 89 01-13-2017 04:41 PM
CARB Compliant WORKS Turbo Kits - Now Available! 50-State Smog Legal! WORKS Forced Induction 47 01-13-2017 04:40 PM
WORKS Stage 1 Turbo Kit - Officially Released! - Now CARB Compliant/SMOG Legal WORKS Forced Induction 230 08-11-2016 06:01 PM
WTB: Used CARB compliant Supercharger TMW Want-To-Buy Requests 0 11-12-2015 06:03 AM
