Old 08-12-2020, 03:35 AM   #1
Joe1990
Drives: 2015 BRZ
2015 BRZ Ticking Noise
4 wonderful years with my brz with zero problems up until recently after taking it in for a oil change. I've noticed that my car sounds a lot louder than usual. It noticeably gets louder while cruising on the freeway, but can't pinpoint the origin of what may be causing it to sound louder. It has 65,000 miles and all basic maintenance has been done to the car promptly. Ive attached a link with a short recording of my car idling and it doesn't seem to sound normal. Any advice would be appreciated!
Joe1990 is offline   Reply With Quote
The Following User Says Thank You to Joe1990 For This Useful Post:
JesseG (08-17-2020)
Old 08-12-2020, 07:38 AM   #2
p1l0t
p1l0t's Avatar
I assume this isn't the classic crickets?
Old 08-12-2020, 10:02 AM   #3
CrowsFeast
CrowsFeast's Avatar
Drives: 2013 BRZ Sport-Tech
Sounds like hydraulic lifters to me (I assume the BRZ has hydraulic lifters, seems like every car does nowadays). Check your oil level just in case but otherwise it's normal.
My car didn't even have the cricket noise until I spun a rod bearing (presumably) and swapped in an engine with lower mileage.
CrowsFeast is offline   Reply With Quote
Old 08-12-2020, 02:30 PM   #4
MJones_RB
MJones_RB's Avatar
I found Toyota overfilled my engine by out 2 quarts. Drained it and refilled with the proper amount. I called them and they said they'd investigate. Never got back to me. Hmm...
Yeah, check your level.
MJones_RB is offline   Reply With Quote
The Following User Says Thank You to MJones_RB For This Useful Post:
JesseG (08-17-2020)
Old 08-13-2020, 02:10 PM   #5
Joe1990
Drives: 2015 BRZ
thanks for the replies! I will double check my oil level today. I do hear the crickets but what i find more concerning is while driving for a prolonged time, about 20 plus minutes, the engine bay starts to sound like a jet airplane. would with be normal due to wear and tear?
Old 08-13-2020, 03:14 PM   #6
p1l0t
p1l0t's Avatar
Does it still make the noise if you are in neutral coasting?
Old 08-13-2020, 09:51 PM   #7
Decep
Drives: 2013 FR-S Series 10
Man do these engines sound like shit
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
The Following User Says Thank You to Decep For This Useful Post:
ToySub1946 (08-14-2020)
Old 08-17-2020, 07:39 AM   #8
SUSPECT_BRZ
SUSPECT_BRZ's Avatar
Drives: 2020 Subaru BRZ TS
As posted on the "other" forum here is my reply :
If this ticking noise has appeared just after the oil change than it's most likely due to what has just been done. Is there any check engine light? Which oil did you use? Different oil viscosity can cause increased noise in a direct injection application. Also did you use the stock oil filter? The stock one is definitely recommended.
From what I hear on your video I would not be too concerned. Check you oil level too. Might also be a pulley starting to go. Definitely nothing internal.
SUSPECT_BRZ is offline   Reply With Quote
engine bay, engine chirping, exhaust sound, idle problem
Clicking / Ticking Rear Noise shellslinger Issues | Warranty | Recalls / TSB 19 07-20-2017 09:40 PM
New coilover ticking noise ItzBidge Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 01-07-2016 08:41 PM
Ticking/Clicking noise when accelerating? Pineapple Issues | Warranty | Recalls / TSB 3 08-28-2014 03:29 PM
Stuttering/ticking noise while car is parked? jermyzy Issues | Warranty | Recalls / TSB 4 03-02-2014 07:35 PM
ticking noise? iHeartmyFR-S Issues | Warranty | Recalls / TSB 13 04-18-2013 05:42 PM
