Old 08-09-2020, 12:28 AM   #1
Sam86
Drives: Toyota 86 GTS
Has anyone removed their FOG light shrouds?
Hi, I'd like to remove my FOG Light/ Front indicator shrouds from my 86 (pre facelift) so that I can apply a tint and possibly paint the shroud.
I've seen two opinions on its removal
1. Some say the bumper must be removed to take it out
2. Others have said they pulled it straight off with the bumper still attached as it apparently is only attached by plastic clips
(to clarify I'm talking about just the plastic pieces that surrounds the fog light and indicator, not the actual fog light)
I'd like to hear from the people who did the 2nd opinion as I can tell from looking at my front bumper tabs that if I pull it off again there's a pretty high chance they'll snap and i'll need to get quick release bumper tabs which I really don't want- which is why i'd like to avoid removing it.
For that same reason I want to know exactly what you did (ie used a trim removal tool, screw driver or just pulled it off) and how much force you used, as me attempting to pull with my hands I could feel the whole bumper being pulled rather than the shroud giving way- and i'm apprehensive about trying to leverage it with a flat head without reassurance in fear that the plastic will snap.
Thanks
Sam86 is offline   Reply With Quote
Old 08-09-2020, 09:59 AM   #2
Joon525
Joon525's Avatar
Drives: 2016 BRZ
Fast forward to 1:36.
Joon525 is offline   Reply With Quote
Old 08-10-2020, 12:19 AM   #3
Sam86
Thanks, mine definitely isn't going to pop off as easily in that video, think mine has more clips in place because of the fog light- but giving it a go with a flat head I was able to at least get a few clips off. More progress than last time I tried at least
I'll buy some plastic tools and give it a proper attempt
Old 09-09-2020, 02:42 AM   #4
Sam86
Here's a before and after of the outcome if anyone planned to do the same. The shrouds were pretty annoying to get off even with trim tools but got there eventually.
The tint I used has some air bubbles that I couldn't remove, probably due to it being a cheap $10 wrap but the tints dark enough it's not really noticeable unless you get up close in person. Might take it off and use a spray tint if it begins to wear
FS (VA): OEM BRZ headlight shrouds subie4 Exterior Parts (Aero, Lighting, Etc.) 13 03-31-2023 02:07 PM
Has anyone removed the 10 Series Light up Emblems yet? Starkiller Cosmetic Modification (Interior/Exterior/Lighting) 58 01-17-2021 02:04 PM
Question to those that have removed 3rd brake light IronDuke Cosmetic Modification (Interior/Exterior/Lighting) 5 02-16-2016 11:35 PM
FS: Cusco Fender Shrouds + APR Brake Ducts jeffs42885 Exterior Parts (Aero, Lighting, Etc.) 1 05-07-2014 11:31 AM
FS: APR CF Ducts / Cusco CF Fender Shrouds jeffs42885 Exterior Parts (Aero, Lighting, Etc.) 6 03-02-2014 01:58 PM
