Old 08-09-2012, 12:57 PM   #1
Jade 86
Jade 86's Avatar
Drives: EVO X & FRS
GT Spec Front Strut Bar (3point)
GT Spec will be releasing this soon..
can't wait to get mine..
Jade 86 is offline   Reply With Quote
Old 08-09-2012, 01:10 PM   #2
deucethemoose
Functionally Retarded
deucethemoose's Avatar
Drives: LinkECU V6 MR2 - MKVII Golf R
1991 MR2 - T-tops - Crimson Red - 1MZ-FE 3.0L - Other Stuff
I'm not really an asshole, but I play one on the internet.
deucethemoose is offline   Reply With Quote
Old 08-09-2012, 01:25 PM   #3
Arnie_1
Drives: Peugeot 106 XSi
I guess you'll have to disconnect this hose to install the GT Spec kit?
Arnie_1 is offline   Reply With Quote
Old 08-09-2012, 01:28 PM   #4
RRnold
2 wheel member
RRnold's Avatar
Drives: JZA80, 997.1, Taco
That's nice!!!!
Old 08-09-2012, 01:30 PM   #5
Jade 86
Jade 86's Avatar
Drives: EVO X & FRS
just asked them they said they will be test fitting monday and see what need to be change.
Old 08-09-2012, 01:30 PM   #6
camelflage
Drives: pinto power
[]http://www.ft86club.com/forums/attachment.php?attachmentid=12341&stc=1&d=13444909 29[/]
oops..
camelflage is offline   Reply With Quote
Old 08-09-2012, 01:37 PM   #7
JadeBRZ
#ProjectBRZ
JadeBRZ's Avatar
Drives: SWP BRZ
or you could just put it over top of the a/c line
JadeBRZ is offline   Reply With Quote
Old 08-09-2012, 01:39 PM   #8
Arnie_1
Perhaps. Would depend on how much it would compress, bend or pinch the hose/line.
Old 08-09-2012, 01:42 PM   #9
JadeBRZ
#ProjectBRZ
JadeBRZ's Avatar
Drives: SWP BRZ
it won't, i just went down and pushed on that line. there is plenty of slack in there. Or you could undo the bracket (for the a/c line) from the firewall and make something to mount it lower so it doesnt stick up so high.
Old 08-09-2012, 02:27 PM   #10
Arnie_1
Ah, super cool. Thanks for checking JadeBRZ! That hose did look like it had a lot of wriggle room.
Old 08-09-2012, 08:43 PM   #11
White64Goat
But then how much does that hose rub on the underside of the brace?? And in more than one place? Looks like a nice piece, but you'd have to recharge the A/C after installing it, it would appear, if you want the hose to go over it.....
Actually it appears that the drivers side that goes out to the strut tower is not welded and you may be able to insert the hose between the bars and the bar has a tab that bolts through the bracket and the strut bolt. Clever if that's how it is done.
Old 08-10-2012, 04:50 PM   #12
Ranatsu
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
When you pressed on the line, did you do it while the A/C was on?
If that is the high pressure hose, it will probably rupture if something is rubbing against it all the time. I had a high pressure line break on my STi when the line was resting on top of the FMIC piping.
Maybe it won't happen, but I think it probably would eventually.
Ranatsu is offline   Reply With Quote
Old 08-10-2012, 05:19 PM   #13
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
If you're worried about that, just wrap a piece of coolant hose or a large piece of convoluted tubing around the AC line.
Old 08-11-2012, 12:19 AM   #14
dunphyjp
dunphyjp's Avatar
Drives: Ultramarine FR-S
WANT.... WANT MEOW!
dunphyjp is offline   Reply With Quote
Cusco Strut Bars Front/Rear for BRZ/FR-S at Redline360 Redline360 Brakes, Suspension, Chassis 0 06-30-2012 11:23 PM
Tanabe Pics of front and rear strut bar! PrimeMotoring Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 06-11-2012 06:02 PM
Front Strut Tower Bar Question russv Scion FR-S / Toyota 86 GT86 General Forum 29 05-22-2012 02:00 AM
