Drives: BRZ & M2
Wing mirrors not working!
Hi guys
My wing mirrors suddenly stopped working ![]() The driver's side only moves up and down while the passenger side doesnt work at all. Could it be the fuse? Any help is greatly appreciated Thanks! P.S. The folding button still works |
If they move at all it isn't a fuse. Did you do anything to the car recently that could have jammed them? Did some water possibly run down into the switch?
| The Following User Says Thank You to Tcoat For This Useful Post: | DarkPira7e (08-04-2020) |
#3 | |
Drives: BRZ & M2
Could there be water ingress in the mirrors? Or the switch is broken? Thanks again |
Not sure about water in the mirrors but possible I suppose. I would be more apt to blame the switch since it works in a couple of directions but not the rest.
Drives: BRZ & M2
Drives: FR-S,GTI
You have folding mirrors?
Where are you from? Is BKK in Korea? I know they are required there. Why, I don't know. They should be required in the UK. The roads are so narrow over there you can tell the American tourists. They're the ones driving rental cars with the passenger mirror dangling on the side from contact with oncoming traffic. But anyway, Are the folding mirrors retrofittable? It would be nice to have one on my passenger side to make more room in the garage. |
If nothing has been done that could have damaged the wiring then yes that would be where I would start.
Here are the links to the service manuals that will help. https://demos.starbase7.net/t3Portal/
#8 | |
https://www.ft86club.com/forums/showthread.php?p=478316
| The Following User Says Thank You to Tcoat For This Useful Post: | WNDSRFR (08-04-2020) |
#9 | |
Drives: BRZ & M2
Could pharoa ants chew on those wires? Had a few of those crawling on the car for a few days. After a few washes I hardly see one. |
#10 | |
Drives: BRZ & M2
![]() Yep BRZs over here are JDM spec and come with power folding mirrors. I lived in the UK for a while and had a Porsche 987S whilst there with no power folding mirrors. Can absolutely relate when parked along narrow pavements and had to manually fold them
#11 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
My first thought would be to check the wiring harness plugs associated with the mirrors to see if they aren't loose or corroded.
One circuit is still working.
"I gotta rock." -- Charley Brown |
#12 | |
Drives: FR-S,GTI
I don't want them that bad. |
| The Following User Says Thank You to WNDSRFR For This Useful Post: | Tcoat (08-04-2020) |
#13 |
Drives: BRZ & M2
Quick update:
Went to the garage just now and tried fiddling with the switch. After flipping the switch and folding/unfolding the Mirror back and forth the passenger side started to Move horizontally!! So now I have driver's side Moving vertically and passenger side horizontally. Should I wait until the car is dry and give it another try? Do I have to play voodoo with the car? xD |
#14 |
Drives: 17 86
| Fender mounted wing mirrors | Khorne | Cosmetic Modification (Interior/Exterior/Lighting) | 15 | 12-18-2020 09:34 PM |
| Removing the side wing mirrors Step by Step Video | tweedbean | DIY (Do-It-Yourself) Guides | 0 | 05-13-2020 03:09 AM |
| Wing Mirrors Folding Sync Issue | FRS2017 | DIY (Do-It-Yourself) Guides | 26 | 08-23-2018 01:36 AM |
| Carbon Effect Wing Mirrors | faz1 | Cosmetic Modification (Interior/Exterior/Lighting) | 11 | 08-25-2012 09:12 PM |
| Do the wing mirrors fold in?? | stevo_12v | AUSTRALIA | 26 | 06-27-2012 10:09 PM |
