Old 08-04-2020, 07:21 AM   #1
V9Rs
Drives: BRZ & M2
Wing mirrors not working!
Hi guys
My wing mirrors suddenly stopped working
The driver's side only moves up and down while the passenger side doesnt work at all.
Could it be the fuse?
Any help is greatly appreciated
Thanks!
P.S. The folding button still works
V9Rs is offline   Reply With Quote
Old 08-04-2020, 07:28 AM   #2
Originally Posted by V9Rs View Post
Hi guys
Thanks!
If they move at all it isn't a fuse. Did you do anything to the car recently that could have jammed them? Did some water possibly run down into the switch?
DarkPira7e (08-04-2020)
Old 08-04-2020, 07:48 AM   #3
V9Rs
Drives: BRZ & M2
It is rainy season over here. I dont think I ever got the switch wet.
Could there be water ingress in the mirrors?
Or the switch is broken?
Thanks again
Old 08-04-2020, 08:18 AM   #4
Thanks again
Not sure about water in the mirrors but possible I suppose. I would be more apt to blame the switch since it works in a couple of directions but not the rest.
Old 08-04-2020, 09:27 AM   #5
V9Rs
Drives: BRZ & M2
Do you think the switch should be the first suspect?
Old 08-04-2020, 09:30 AM   #6
WNDSRFR
Drives: FR-S,GTI
You have folding mirrors?
Where are you from? Is BKK in Korea? I know they are required there. Why, I don't know.
They should be required in the UK. The roads are so narrow over there you can tell the American tourists. They're the ones driving rental cars with the passenger mirror dangling on the side from contact with oncoming traffic.
But anyway, Are the folding mirrors retrofittable? It would be nice to have one on my passenger side to make more room in the garage.
Old 08-04-2020, 09:31 AM   #7
If nothing has been done that could have damaged the wiring then yes that would be where I would start.
Here are the links to the service manuals that will help.
https://demos.starbase7.net/t3Portal/
Old 08-04-2020, 09:33 AM   #8
Anything can be done if you want it bad enough. Not cheap I would guess
https://www.ft86club.com/forums/showthread.php?p=478316
WNDSRFR (08-04-2020)
Old 08-04-2020, 09:40 AM   #9
V9Rs
Drives: BRZ & M2
Cheers for that
Could pharoa ants chew on those wires?
Had a few of those crawling on the car for a few days. After a few washes I hardly see one.
Old 08-04-2020, 09:51 AM   #10
V9Rs
Drives: BRZ & M2
BKK is Bangkok
Yep BRZs over here are JDM spec and come with power folding mirrors.
I lived in the UK for a while and had a Porsche 987S whilst there with no power folding mirrors. Can absolutely relate when parked along narrow pavements and had to manually fold them
Old 08-04-2020, 11:04 AM   #11
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
My first thought would be to check the wiring harness plugs associated with the mirrors to see if they aren't loose or corroded.
One circuit is still working.
Old 08-04-2020, 11:52 AM   #12
WNDSRFR
Drives: FR-S,GTI
Nevermind.
I don't want them that bad.
The Following User Says Thank You to WNDSRFR For This Useful Post:
Tcoat (08-04-2020)
Old 08-04-2020, 12:45 PM   #13
V9Rs
Drives: BRZ & M2
Quick update:
Went to the garage just now and tried fiddling with the switch.
After flipping the switch and folding/unfolding the Mirror back and forth the passenger side started to Move horizontally!!
So now I have driver's side Moving vertically and passenger side horizontally.
Should I wait until the car is dry and give it another try?
Do I have to play voodoo with the car? xD
Old 08-04-2020, 01:50 PM   #14
PetrolioBenzina
PetrolioBenzina's Avatar
Drives: 17 86
WD40 Contact Cleaner
PetrolioBenzina is offline   Reply With Quote
Fender mounted wing mirrors Khorne Cosmetic Modification (Interior/Exterior/Lighting) 15 12-18-2020 09:34 PM
Removing the side wing mirrors Step by Step Video tweedbean DIY (Do-It-Yourself) Guides 0 05-13-2020 03:09 AM
Wing Mirrors Folding Sync Issue FRS2017 DIY (Do-It-Yourself) Guides 26 08-23-2018 01:36 AM
Carbon Effect Wing Mirrors faz1 Cosmetic Modification (Interior/Exterior/Lighting) 11 08-25-2012 09:12 PM
Do the wing mirrors fold in?? stevo_12v AUSTRALIA 26 06-27-2012 10:09 PM
