HELP!! P0020 CEL on Scion FR-S
Sooooo basically how this code came about, as I was driving to work in the early am, I wasn’t driving crazy or anything just cruising, and all of a sudden I get a cel. I have an OFT and I attempted to erase it via the OFT but as soon as the cel is erased it immediately comes back so I’m assuming it’s something serious I’m not sure. The car has been on a stage 2+ (85) tune for the past year, the car till this very moment runs normal, obviously the car isn’t performing like it’s supposed to with this cel on. Went to the dealer yesterday told me they couldn’t figure out any way of fixing the problem which kind of surprised me. My next step is to go to a legit tuner and see what he can do maybe, hopefully he can remove the cel? or is there something else I can do to fix this code P0020. The car has aftermarket headers, aftermarket exhaust system, and car has around 87k miles. I really don’t know what it could be, maybe bad ECM even?? I honestly have no clue what to do and I’m stuck with an even slower FR-S
![]() Thanks again for responses/help
9x out of 10 it is just the sensor. There are 4. I would move it to another spot and see if the bank changes. If it does replace that sensor with a new one and you are good to go. (Sometimes moving it will get worse / not even start but that's fine you can just move it back. Just make sure the car is not blocking anyone type of deal.) A small socket is all you need I don't even jack it up, even for the ones on the bottom but it takes a little finess. If it is not the sensor it could be a few things, like overfilling your oil, the PCM, but these camsensors is the sensor itself that goes faulty on you. If you have a multimeter you can compare sensors that way too if you don't want to run the engine. One of them will read the wrong oHms that's the bad one.
![]() Sent from my SM-G975U using Tapatalk |
#3 | |
P0020 Toyota
Featured snippet from the web P0020 is the OBD-II generic code indicating that the engine control module (ECM) has determined that the bank 2 intake camshaft Oil Control Valve (OCV) has an open or short circuit. This happens during one drive cycle.
#5 | |
![]() You turn the dial to the symbol that looks like this. Sent from my SM-G975U using Tapatalk |
| CEL P0020 - "A" Camshaft Position Actuator... | raul | Issues | Warranty | Recalls / TSB | 5 | 11-28-2017 03:55 PM |
| CEL P0020 - "A" Camshaft Position Actuator... | raul | Tracking / Autocross / HPDE / Drifting | 7 | 09-25-2017 03:01 PM |
| RightFootDown-Video: Stock Scion FRS versus Turbo Scion FRS, Street Comparison | kanundrum | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 0 | 06-09-2015 12:47 PM |
| Scion FR-S Behind the Scenes with Scion VP Jack Hollis scion | UriarteMD | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 19 | 06-14-2011 07:13 PM |
