Old 07-29-2020, 12:25 PM   #1
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
Trying to decide on Coilovers
Like the title says, I’m trying to decide on coilovers for my car. I’ve narrowed it down to Revel and Meister R Zeta coilovers. I don’t track my car, but do some spirited driving (I DD my car). I’ve had Eibach Pro Springs in my car (OEM struts) for over 70k miles and am looking for a change. I’m not looking for a super slammed stance. I’d like to keep it about the same height as the Eibachs. I appreciate any firsthand feedback and advice on these two options.
And yes I’ve searched.
kmbkk is offline   Reply With Quote
Old 07-29-2020, 12:33 PM   #2
StraightOuttaCanadaEh
Wes
Don't get the Zeta, damping isn't great and they're too softly sprung imo. Set it towards soft and there is too much compression over dips and weird lateral movement in the constant radius corners like on-ramps, set it on hard and it handles sharper but the ride becomes brutal, only suitable for pool table smooth roads
Instagram: @gt86ws
Old 07-29-2020, 12:56 PM   #3
Racecomp Engineering
Have you considered replacing the stock struts with Bilstein B6?
Not saying that's the only option, but it's an easy and good one at decent price.
- Andrew
Old 07-29-2020, 01:31 PM   #4
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
Find some local ones in 86 groups for sale/cheap.
I grabbed a set of Tein Flex Zs with only 15k miles on them for four hundred bucks.
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
Old 07-29-2020, 03:45 PM   #5
kmbkk
kmbkk's Avatar
Drives: FR-S, Flex
- Andrew
I was looking primarily at coilovers, but would consider struts
Old 07-29-2020, 03:47 PM   #6
kmbkk
kmbkk's Avatar
Drives: FR-S, Flex
Thanks for the feedback!
Old 07-29-2020, 03:48 PM   #7
kmbkk
kmbkk's Avatar
Drives: FR-S, Flex
I haven’t seen any lately but I’ll keep an eye out.
Old 07-29-2020, 06:30 PM   #8
Westen86
Purist
Westen86's Avatar
Drives: 2013 FRS - Hot Lava
Fortune 500
Apexi EXV
RSR Sports
ST Suspension
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85)
Westen86 is offline   Reply With Quote
Old 07-30-2020, 09:43 AM   #9
The damper in the Bilstein B6 is much better than anything you'll find under $1k. No height or damping adjustability, but it's just a better overall part.
If you're happy with your current ride height, it makes a lot of sense especially for a DD.
I would consider coilovers if you have a little more in your budget and/or you track or auto-x your car. There are coilovers that are plenty good for a daily driver, but IMO not under $1k.
- Andrew
Old 07-30-2020, 09:52 AM   #10
Mike_ZN6
Mike_ZN6's Avatar
Drives: 2016 Toyota 86
You didn't say how much you want to spend?
If you want to go the cheapest route I think BC Racing BR coilovers are the best for under $1,000.
If you can, I would suggest spending about $1,500 and getting RCE SS-1.
Old 07-30-2020, 10:23 AM   #11
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I gave a set of Flex Z's away not that long ago lol. They are a decent budget option.
I don't see the point in running coilovers unless you are doing AutoX, track days, or you are just looking to slam your car. Don't cheap out to just end up with a worse ride and no performance gain.
Old 07-30-2020, 10:58 AM   #12
Ernest72
Drives: 16 Silver BRZ, 04 Silver WRX wagon
OP - I am at 52k and plan on doing suspension at 80k (about 2 years from now). My plan after much research was to lower car slightly with RCE yellows and B6 struts for DD and spirited driving. Most advice from other threads has been this is a better option than cheaper coilovers. It appears you need to spend more than 1k to get better dampening in the available coilovers. Since I don’t track, I don’t see the need to spend more for coilovers. But I will reassess in 2 years, maybe opinions will change.
Ernest72 is offline   Reply With Quote
Old 07-30-2020, 02:10 PM   #13
nathand
Drives: 2016 HyperBlue
The B6 are ~$800 and RCE Yellow are ~$340, so total cost is ~$1140. (and you should probably add new strut tops all around)
For me that is really close (~30% more) to move up to $1500 for the RCE SS-1 which also gives you new tops in the front.
Andrew can you give a more detailed comparison between the two and when you would choose one over the other?
nathand is offline   Reply With Quote
Old 07-30-2020, 02:19 PM   #14
Have you considered the CSG spec Flex A? They'd be perfectly suited for what you're looking for based on your post.
Maximum compliance while getting you the cornering response you want.
please help me decide brzultra Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 08-04-2019 05:49 PM
Coilovers Coilovers, Coilovers: Tein, KW, BC, D2, Cusco, Eibach + more FREE SHIPPING! No Limit Motorsport Brakes, Suspension, Chassis 204 05-26-2017 12:09 PM
New here, looking to decide on coilovers. dito Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 03-27-2015 08:38 AM
Looking to buy TOM'S but can't decide !!! Pish Cosmetic Modification (Interior/Exterior/Lighting) 21 06-17-2014 01:26 PM
Help me decide Decoy68 Other Vehicles & General Automotive Discussions 0 06-18-2012 08:29 PM
