Drives: 2013 FRS
Door Panel replacement for track cars
So whats the solution for replacing the factory door panels on a track car when you have it caged? I would like to accommodate the switch cluster and some sort of pull handle. Any suggestions?
WIFE: "How can there be anything left to buy?"
Drives: '24 GR86
I’ve seen bare doors on most cars.
Street Faction and LRB make some panels. TRD has some awesome carbon ones. But be prepared to have a very light wallet if you get those lol
| The Following User Says Thank You to TylerLieberman For This Useful Post: | bmacfrs (07-29-2020) |
Rust bucket enthusiast
Someone has some aluminum ones for sale here - https://www.ft86club.com/forums/showthread.php?t=139681
| The Following User Says Thank You to DarkPira7e For This Useful Post: | bmacfrs (07-29-2020) |
Site Moderator
Drives: Stuff
I just didn't bother with a panel. The plastic will come out and the rubber crap will be cleaned up after the cage gets welded in since I'll be doing some painting anyways.
I just bolted them back to existing spots. The window switches I'll secure with a second self taping screw later after the cage is in so I can make sure it clears - or I'll just remove the window switches and plug them in only when I need the windows to move (start and end of the track event) which is what I do with my ITR currently. Broke the locking clip off so it takes a few seconds to plug in, move the windows and remove the switches again.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
| The Following User Says Thank You to Dave-ROR For This Useful Post: | bmacfrs (07-30-2020) |
Undisputed El Presidente
Drives: Zenki 37J ZN6
Spinnywoosh sells aluminum ones. bare or with a design
https://spinnywhoosh.com/collections...12566634659918 |
| The Following User Says Thank You to finch1750 For This Useful Post: | bmacfrs (07-30-2020) |
#6 | |
Drives: 2013 SWP BRZ Ltd. / E60 M5
2013 BRZ Limited | SWP | Verus Ventus 1 and High-Efficiency Rear Wing | Invidia N1 Ti | JR Oil Cooler | RCE T2 | RaceSeng Cas/Cam | SPL LCA & TA | Wilwood/RR Racing Stage II/Sport Performance | XP10 | Apex ARC-8 | Toyo R888R | 245/40-17 | Sparco Ergo II/Evo II | AIM MXP | SmartyCam GP HD 2.2
| The Following 2 Users Say Thank You to Alan For This Useful Post: | ML (08-10-2020), soundman98 (08-09-2020) |
I have been looking for a door panel solution too. Would love something like the TRD panels, but they are way to expensive for a track rat.
This guy did something similar to the LRB panels. You could probably duplicate this out of other materials too. I wish someone would make something like this for our cars. http://www.hardmotorsport.com/hard-m...bmw-e46-coupe/
#8 | |
Site Moderator
Drives: Stuff
I wouldn't mind using sheet aluminum to make a panel and attach with some bolts (can easily install some rivnuts in the door sheet metal) but again.. time/money vs value is pretty limited on that mod. Looks pretty though!
-Dave
| The Following User Says Thank You to Dave-ROR For This Useful Post: | Alan (08-10-2020) |
| Rear quarter panel replacement | sero901 | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 5 | 09-25-2015 12:41 PM |
| Replacement Auxiliary Panel With Momentary Switches | Stang70Fastback | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 08-26-2015 04:42 PM |
| ****---> wtb door panel | WATCHMEHEAL | Want-To-Buy Requests | 0 | 07-30-2014 11:58 PM |
| 10-Series Electroluminescent Dash Panel Replacement | Raiin | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 11-18-2013 01:14 PM |
| Is there an aftermarket replacement for this panel? | JordanWho | Cosmetic Modification (Interior/Exterior/Lighting) | 27 | 03-07-2013 03:57 PM |
