Old 07-29-2020, 08:18 AM   #1
bmacfrs
bmacfrs's Avatar
Drives: 2013 FRS
Door Panel replacement for track cars
So whats the solution for replacing the factory door panels on a track car when you have it caged? I would like to accommodate the switch cluster and some sort of pull handle. Any suggestions?
WIFE: "How can there be anything left to buy?"
bmacfrs is offline   Reply With Quote
Old 07-29-2020, 10:04 AM   #2
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
I’ve seen bare doors on most cars.
Street Faction and LRB make some panels.
TRD has some awesome carbon ones. But be prepared to have a very light wallet if you get those lol
The Following User Says Thank You to TylerLieberman For This Useful Post:
bmacfrs (07-29-2020)
Old 07-29-2020, 01:03 PM   #3
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Someone has some aluminum ones for sale here - https://www.ft86club.com/forums/showthread.php?t=139681
Old 07-30-2020, 11:11 AM   #4
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I just didn't bother with a panel. The plastic will come out and the rubber crap will be cleaned up after the cage gets welded in since I'll be doing some painting anyways.
I just bolted them back to existing spots. The window switches I'll secure with a second self taping screw later after the cage is in so I can make sure it clears - or I'll just remove the window switches and plug them in only when I need the windows to move (start and end of the track event) which is what I do with my ITR currently. Broke the locking clip off so it takes a few seconds to plug in, move the windows and remove the switches again.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
bmacfrs (07-30-2020)
Old 07-30-2020, 02:09 PM   #5
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Spinnywoosh sells aluminum ones. bare or with a design
https://spinnywhoosh.com/collections...12566634659918
Old 08-09-2020, 06:23 PM   #6
Alan
Alan's Avatar
Drives: 2013 SWP BRZ Ltd. / E60 M5
This guy had a good idea and I suppose lengthened the harness to put the window/mirror switches on the dash.
2013 BRZ Limited | SWP | Verus Ventus 1 and High-Efficiency Rear Wing | Invidia N1 Ti | JR Oil Cooler | RCE T2 | RaceSeng Cas/Cam | SPL LCA & TA | Wilwood/RR Racing Stage II/Sport Performance | XP10 | Apex ARC-8 | Toyo R888R | 245/40-17 | Sparco Ergo II/Evo II | AIM MXP | SmartyCam GP HD 2.2
Alan is offline   Reply With Quote
The Following 2 Users Say Thank You to Alan For This Useful Post:
ML (08-10-2020), soundman98 (08-09-2020)
Old 08-09-2020, 06:34 PM   #7
Alan
Alan's Avatar
I have been looking for a door panel solution too. Would love something like the TRD panels, but they are way to expensive for a track rat.
This guy did something similar to the LRB panels. You could probably duplicate this out of other materials too.
I wish someone would make something like this for our cars. http://www.hardmotorsport.com/hard-m...bmw-e46-coupe/
Old 08-09-2020, 10:36 PM   #8
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
That's pretty slick - I might consider moving them to my switch panel (where the radio was) if I have some time to do that someday. For now I think I'll do the install/uninstall when loading/unloading from the trailer. The car is normally traveling in an enclosed trailer so I might not even run them up all that often.
I wouldn't mind using sheet aluminum to make a panel and attach with some bolts (can easily install some rivnuts in the door sheet metal) but again.. time/money vs value is pretty limited on that mod. Looks pretty though!
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Alan (08-10-2020)
Rear quarter panel replacement sero901 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 5 09-25-2015 12:41 PM
Replacement Auxiliary Panel With Momentary Switches Stang70Fastback Cosmetic Modification (Interior/Exterior/Lighting) 3 08-26-2015 04:42 PM
****---> wtb door panel WATCHMEHEAL Want-To-Buy Requests 0 07-30-2014 11:58 PM
10-Series Electroluminescent Dash Panel Replacement Raiin Cosmetic Modification (Interior/Exterior/Lighting) 0 11-18-2013 01:14 PM
Is there an aftermarket replacement for this panel? JordanWho Cosmetic Modification (Interior/Exterior/Lighting) 27 03-07-2013 03:57 PM
