Old 07-27-2020, 12:43 AM   #1
Pop
Drives: Scion FR-S 2013
FRS won't start
Hi, my FRS won't start, I was driving normally to work, then my car made a loud rev and went to max rpm on it's own, then I tried to accelerate but it won't go. I parked on the side of the road and tried to restart the car but nothing is happening. Now my car won't start. Now I here this weird rotating sound when I try to start the engine. I'm wondering if any of you guys know what's happening.
Pop is offline   Reply With Quote
The Following User Says Thank You to Pop For This Useful Post:
humfrz (07-27-2020)
Old 07-27-2020, 02:25 AM   #2
humfrz
Hi ya, Pop and welcome to the group. -
Standard questions:
* how many miles on your car?
* is it still under warranty?
* do you have any power mods?
When was the last time you gassed up?
Does the car turn over when you try to start it or it turns over and won't fire?
Now, your car isn't out of gas is it? - sorry, I had to ask. -
Come back.
Old 07-27-2020, 03:41 AM   #3
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Sound like he ran out of gas.
The Following User Says Thank You to Mr.ac For This Useful Post:
humfrz (07-27-2020)
Old 07-27-2020, 08:40 AM   #4
Need far more info but "went to max revs" and "weird rotating sound when starting" would seem like a flywheel issue to me. Any and all guesses at this point are pretty much valueless though since there are hundreds of things it could be with the limited information we have.
humfrz (07-27-2020)
Old 07-27-2020, 04:53 PM   #5
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
It's a 2013. Probably valve spring recall. RIP
Clueless
YamahaR86 is offline   Reply With Quote
Old 07-27-2020, 06:16 PM   #6
Pop
[QUOTE=humfrz;3352289]Hi ya, Pop and welcome to the group. -
Standard questions:
When was the last time you gassed up?[QUOTE]
It's an 2013 FRS. Milage is 131,339. Not under warranty. No power mods. I fully pumped gas that morning. When I start the car it turns slowly like two metal rubbing against each other and that's all that happens.
humfrz (07-27-2020)
Old 07-27-2020, 08:55 PM   #7
humfrz
[QUOTE=Pop;3352478]
OK.
So, after you put gas in the car, how far did you drive it before it stopped on you? Now, you didn't pump out of a diesel tank did you? (sorry, I had to ask). Was that station your usual fueling place? (bad (water) in the gas)?
Now, when you hear the sound of two metal (what's) rubbing together??), is the engine turning over or just the starter?
Are you on the original battery? Is the battery strong?
Have you had problems like this before?
Does the dash show a CEL?
Do you have a OBD reader that you could read any fault codes?
Come back.
Old 07-27-2020, 09:00 PM   #8
humfrz
Reminds me of back in the day it CT, when this cute neighbor lady, wearing a bikini, was trying to start her lawn mower in her front yard ..... oh, I think I've told that story before -
Mr.ac (07-28-2020)
Old 07-27-2020, 10:18 PM   #9
Pop
[QUOTE=humfrz;3352522]
OK.
Come back.
I was on the highway driving 60mph then my car reved on it's own for about 2 secs, right after that I pushed the gas pedal and nothing happened. I pushed it a couple more time and nothing, no acceleration. I had full tank before I entered the highway. I pump 91 at the same Kwik Trip every week. The metal rubbing is coming around the crankshaft area. Battery was working when the car stopped on me. Never had problems with it. When the car died on me my check engine light, oil, and battery went on at the same time and is still on when I put the key in. I don't have a code reader to check. I have a video you guys can look at, put the volume at max. you can hear the problem I'm trying to describe.
PLEASE WATCH VIDEO
I THINK IT WILL HELP FIGURING OUT THE PROBLEM
LINK:
humfrz (07-27-2020)
Old 07-27-2020, 11:06 PM   #10
humfrz
Well, Pop, that sounds like the starter spinning but not engaging the flywheel.
If that is what it is, the starter solenoid may be shot and it's not pushing the gear into the flywheel. If it is a starter problem, a new starter would be in order.
If it is a manual transmission car, have you tried to push start it?
Come back.
Old 07-27-2020, 11:30 PM   #11
Pop
Come back.
It's an automatic with twist to start with key. So it may be the starter causing this?
humfrz (07-27-2020)
Old 07-27-2020, 11:59 PM   #12
humfrz
I can't be certain if it is a bad starter.
When you are trying to start it and something is making that noise, is the engine turning over? (do the pulley belts move?)
Old 07-28-2020, 12:43 AM   #13
Pop
I looked at all the rotating wheels for the belt and none is moving, you think it could be the crankshaft that's broken?
humfrz (07-28-2020)
Old 07-28-2020, 01:59 AM   #14
humfrz
Well, if that sound we hear when you are trying to start the car is just the starter spinning, then either it is not pushing the gear on the end of the shaft into the flywheel or all the teeth are ground off of that gear or there are no teeth left on the flywheel where the starter is trying to make contact.
Even if that (or some of it) is true, that doesn't explain why your car stopped running on you.
Back in the day, I would have taken the starter off and examined and bench tested it. If it failed, I would have purchased a new (or remanufactured) starter and installed it.
However, today, in my lazy mode, I would call up the guys at my local auto shop and have them come pick up my car, take it to their shop and fix it.
If, after they get it to start, and it doesn't run right and they can't get it to run better, I'd ask them to drag it down to the dealer and ask the dealer to fix it.
As far as why your car spirted and then stopped on you could have been caused by many different things. A code reader (an inexpensive one would be a good investment for you) may be able to give you a hint as to why the car stopped running.
Back in the old days, before all this computer code reading BS and a car stopped running, we would have started by finding out which ingredient was lacking (fuel, spark, timing or compression). I'm leaving one out to see if anyone is paying any attention. -
Maybe some of the other fellows will come along with some suggestions.
I hope you get er going.
Stall/No Re-start with push button start couver Scion FR-S / Toyota 86 GT86 General Forum 11 06-26-2020 10:32 PM
FS: STI engine start push start OEM plug and play sokol Interior Parts (Incl. Lighting) 5 06-13-2019 02:12 PM
Pushed start.. didnt start im_topher Engine, Exhaust, Transmission 86 11-29-2015 09:57 AM
Pop-Start with Push-Button Start cmspooner BRZ First-Gen (2012+) — General Topics 5 03-22-2013 02:45 PM
Push Start Rough Engine Start Up joergasm Engine, Exhaust, Transmission 3 12-12-2012 03:44 AM
