Old 07-16-2020, 10:03 AM   #1
Ashikabi
Ashikabi's Avatar
Using a muffler as a helmholtz resonator
Morning boys,
My LS1 swapped FRS is too quiet. But the ideal resonator length is impractical without a second bend. So my question is: if I cap one end, will a short fat muffler operate similarly to a much longer resonator when attached at a90 degree angle?
Old 07-16-2020, 10:44 AM   #2
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Your LS1 V8 is too quiet?? O_o
MS, CSCS, TSAC-F, CPT
Old 07-16-2020, 10:53 AM   #3
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Morning boys,
Absolutely no idea on capping a muffler to be a resonator.... but if you do this can you take pictures and sound clips.
I used an SLP LM1 as a resonator in my custom exhaust, but obviously not as a helmholz chamber.
Old 07-16-2020, 10:56 AM   #4
Ashikabi
Ashikabi's Avatar
Dual pipes with 2 mufflers. It's not QUIET but it's not loud. I tried it the other day with no mufflers and it droned like a bastard. But it sounded good otherwise lol
Old 07-16-2020, 11:00 AM   #5
solidsnake11
Drives: brz
Did the exhaust end under the car? If it did, extend it out the back and test again.
solidsnake11 is offline   Reply With Quote
Old 07-16-2020, 11:08 AM   #6
Summerwolf
Panda Trueno
Summerwolf's Avatar
Can you use one of those crossover X mufflers with the way its routed? Heard a bunch of LS cars using just that, always seemed pretty decent to me.
Old 07-16-2020, 11:09 AM   #7
Ashikabi
Ashikabi's Avatar
Yes it did, I just pulled my mufflers off
Old 07-16-2020, 11:10 AM   #8
Ashikabi
Ashikabi's Avatar
Originally Posted by Summerwolf View Post
Can you use one of those crossover X mufflers with the way its routed? Heard a bunch of LS cars using just that.
X pipes aren't mufflers but I have heard of them making exhaust quieter. I think that would be too difficult to play with to make it worth it. Since they can't be altered easily
Old 07-16-2020, 01:55 PM   #9
solidsnake11
Drives: brz
Huge difference in cabin volume between under the car vs out the back.
I had a 6 inch extension for my old 7m toyota pick up that would cut noise in half in the cab, used it, unless I was racing. The exhaust ran out the side under the door. Flush with body vs 6 inches out.
Old 07-16-2020, 02:19 PM   #10
Summerwolf
Panda Trueno
Summerwolf's Avatar
I specifically said crossover x muffler.
https://www.jegs.com/i/Dynomax/289/1...SABEgKTrPD_BwE
Magnaflow, dynomax, almost everyone makes a muffler casing with a crossover built in. Don't know what your setup under the car looked like.
Old 07-16-2020, 02:24 PM   #11
Ashikabi
Ashikabi's Avatar
I want aware something like this even existed. If it's not too long I could make it work
Helmholtz resonator pointless on a turbo car? Kiske Forced Induction 2 12-14-2015 10:15 AM
Will Helmholtz resonator decrease power? shu5892001 Engine, Exhaust, Transmission 31 01-07-2015 09:37 AM
FS: SoCal - Nameless catted downpipe w/ Helmholtz resonator AspenItIs Engine, Exhaust, Bolt-Ons 17 10-31-2014 05:56 PM
Nameless 3" downpipe Helmholtz Resonator or not skyloran Engine, Exhaust, Transmission 1 06-04-2014 05:12 PM
Ordering Nameless Exhaust - Helmholtz Resonator?? Umbie Engine, Exhaust, Transmission 16 12-03-2012 01:48 PM
