Old 07-14-2020, 02:10 PM   #1
jeffs42885
Drives:
Issue with rear suspension
So I have an issue with my 2015. I just put gram lights on. 18x8.5 +37 with factory TRD springs. 235/40/18.
Drivers side rubs. Took it to my friend who’s a suspension guy and we put it up on the alignment lift. We noticed that the drivers side sticks out a little more than the passenger side. And he said the tow could be off.
I’m starting to think this car was in an accident and the former seller didn’t disclose. Car fax was clean. Also, had the suspension looked at. No signs of damage. Anything bent. Subframe is okay. Etc. my friend suggested something along the lines of taking it apart. Putting it back together and seeing if that could possibly fix the issue. I’m not a suspension guy so any feedback is appreciated!
Here’s the pics.
[IMG]https://uploads.tapatalk-cdn.com/20200714/8243f2734317c2d58223939***428aea.jpg[/IMG]
jeffs42885 is offline   Reply With Quote
The Following User Says Thank You to jeffs42885 For This Useful Post:
JesseG (07-14-2020)
Old 07-14-2020, 02:41 PM   #2
humfrz
Good looking car!
Would a spacer make it better or worse -
JesseG (07-14-2020)
Old 07-14-2020, 02:48 PM   #3
LimitedSlip
Senior Citizen Member
LimitedSlip's Avatar
How about verifying the offset on all of the new wheels? Actually measure it just on the chance that you received one that was not what you ordered.
LimitedSlip is offline   Reply With Quote
The Following 2 Users Say Thank You to LimitedSlip For This Useful Post:
humfrz (07-15-2020), JesseG (07-14-2020)
Old 07-14-2020, 03:48 PM   #4
jeffs42885
Drives:
Yeah, I did. Stamped +37 18x8.5
Also OEM wheels look similar just don’t rub
Old 07-14-2020, 05:48 PM   #5
JesseG
JesseG's Avatar
Drives: 2016 Scion FR-S
First of all, your car looks bada$$
Secondly, did you measure the offset of each wheel? Like physically measure not go by the stamping on the wheel. I’m not exactly sure how you go about doing that accurately though.
Did you notice anything before switching to the new wheels?
JesseG is offline   Reply With Quote
Old 07-14-2020, 06:04 PM   #6
jeffs42885
Drives:
I didn’t. But I put the stock ones on and it’s the same
JesseG (07-16-2020)
Old 07-14-2020, 10:35 PM   #7
Decep
Drives: 2013 FR-S Series 10
That seems like a huge difference from that pic. /subbed
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
Old 07-15-2020, 12:51 AM   #8
humfrz
Have you tried rotating them front to back (to see if one rim/tire is whacked out)?
Old 07-15-2020, 09:52 AM   #9
jeffs42885
Drives:
I didn’t but like I said, on the stock wheels and tires there’s still a difference.
Old 07-15-2020, 09:56 AM   #10
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
What were the alignment specs? Do you have adjustable lower control arms?
It could just be the angle, but the drivers side wheel looks like it has more camber. The rear caber is not adjustable on the car so it either has adjustable LCAs or something is bent.
BigTuna is offline   Reply With Quote
The Following 3 Users Say Thank You to BigTuna For This Useful Post:
humfrz (07-15-2020), Ohio Enthusiast (07-15-2020), thomasmryan (07-25-2020)
Old 07-15-2020, 11:22 AM   #11
jeffs42885
Drives:
Stock suspension other than the TRD springs. Nothing looks bent.
Old 07-15-2020, 01:25 PM   #12
Grady
Grady's Avatar
I would take everything apart and check all components. Also check subframe mounts to car. Previous owner may have curbed it. If all looks good you. May be able to get things to line up with the Whitline adjustable upper mounts and lower adjustable control arms. Move upper mount all the way out on the left and all the way in on the right, then adjust alignment with the lower.
The Following User Says Thank You to Grady For This Useful Post:
humfrz (07-15-2020)
Old 07-15-2020, 03:22 PM   #13
CrowsFeast
CrowsFeast's Avatar
Drives: 2013 BRZ Sport-Tech
How close to rubbing is the passenger side? Every manufactured part has tolerances (however tight those may be). When the sub-frame is mounted it can and will shift slightly to one side or the other as well.
You might just have picked a setup that is so tight it could fit on some cars and not on others. If you loosen the sub-frame and adjust it (or remove to inspect and then reinstall) then you may find that they no longer rub driving straight, but then rub when you corner (movement in the rubber sub-frame bushings).
CrowsFeast is offline   Reply With Quote
The Following User Says Thank You to CrowsFeast For This Useful Post:
soundman98 (07-15-2020)
Old 07-16-2020, 10:30 AM   #14
jeffs42885
Drives:
That’s my plan in the fall.
Strange Rear Suspension Issue dvniemela Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 04-28-2018 09:35 PM
Help with suspension issue arkanist Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 04-06-2018 05:59 PM
Suspension issue? Dacfrs Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 12-08-2017 09:25 PM
Need Help with Suspension Issue Silverfox Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 08-04-2017 12:44 PM
Squeaking / Creaking rear suspension with low ride height? Suspension pros welcome! mothespaceman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 08-14-2015 05:06 PM
