Old 07-09-2020, 07:08 PM   #1
Zee7
Drives: 2018 BRZ
Charge coolers
Has anyone installed a killer cooler (or similar system) on our cars, id like to pick your brain.
For those unfamiliar they are an intercooler system tied to your AC system to cool your charge temps.
Zee7 is offline   Reply With Quote
Old 07-09-2020, 09:15 PM   #2
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
I have not, but I believe the Dodge Demon has such a setup. The WRX STI has used a water spray on the intercooler to cool that down. People squirt nitrous on intercoolers too, so there are many options out there. How effective they are depends on the system and the conditions. Obviously they are effective, or they wouldn’t exist, but they are usually to maximize power during a race or pass situation. I believe some cars have a F1-similar over-boost setup for when a little extra power is desired.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
soundman98 (07-10-2020)
Old 07-09-2020, 09:18 PM   #3
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I would think a simple intercooler mister would be a lot easier. Make sure it's misting, not spraying a ton of water on the intercooler.
The Following User Says Thank You to DarkPira7e For This Useful Post:
Old 07-10-2020, 11:12 AM   #4
ls1ac
ls1ac's Avatar
Most cars today turn off the AC compressor when in WOT. When normal running there is a substantial parasitic load from the AC. I guess there might be a benefit to precooling the unit but that would not last very long.
The Following User Says Thank You to ls1ac For This Useful Post:
DarkPira7e (07-10-2020)
Oil Coolers AldoRaine Forced Induction 4 05-31-2020 01:10 PM
Dual Oil Coolers? Why not? megamarines Engine, Exhaust, Transmission 23 09-04-2015 11:21 PM
Oil coolers Matey Forced Induction 37 03-13-2015 08:21 AM
those with perrin oil coolers bkblitzed Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 10 12-08-2013 12:34 AM
HKS Oil Coolers in stock Sam Strano Engine, Exhaust, Bolt-Ons 3 11-13-2012 01:41 PM
