Old 07-03-2020, 07:42 PM   #1
zberz
Drives: 2015 Lightning Red BRZ
SPAL fan wiring
Installing the JDL kit and picked up an FBM shroud with Spal fans. I don't really want to cut the stock fan connectors on the harness, but I'm not finding compatible male connectors. Any advice? What do you all do when installing spal fans? I'm trying to keep things waterproof.
Sent from my SM-G950U using Tapatalk
zberz is offline   Reply With Quote
Old 07-03-2020, 11:01 PM   #2
Use an external relay. OEM fan signal -> ignitor, relay power source to fan power. Ground is ground.
Old 01-13-2025, 11:31 AM   #3
RT-BRZ
RT-BRZ's Avatar
Drives: 2013 Subaru BRZ
I'm trying to figure this out as well. I've created a diagram. Does this look correct?
RT-BRZ is offline   Reply With Quote
Old 01-14-2025, 05:54 PM   #4
I believe that looks right.
RT-BRZ (01-14-2025)
Spal Fan Install djezlee Engine, Exhaust, Transmission 6 09-03-2022 01:16 AM
Spal Fan Shroud & Koyo Radiator Carolina Dyno Forced Induction 64 12-14-2016 09:38 PM
***JDL Auto Design Low Profile SPAL Fan Shroud kit*** JDLAutoDesign Engine, Exhaust, Bolt-Ons 18 11-13-2015 12:54 PM
***JDL Auto Design Low Profile SPAL Fan Shroud kit*** JDLAutoDesign Engine, Exhaust, Bolt-Ons 74 09-03-2015 01:34 PM
Stock radiator + aftermarket Shroud to fit SPAL fans jflogerzi Forced Induction 18 09-09-2014 12:55 AM
