Old 03-06-2019, 10:19 AM   #1
djezlee
Drives: 2017 BRZ Limited
Spal Fan Install
I ordered the JDL Slim Fan shroud with the Spal fans, and haven't received any assistance from 86 Speed for the wiring part of the install. Can anyone advise me on how they wired their fans up? With relays to use... where to tap into the factory fuse box?
djezlee is offline   Reply With Quote
Old 03-06-2019, 12:14 PM   #2
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
For the slim fans, you can wire them into the original fan wiring without relays because the max current they pull is below the rating of the fuses. Using the original connector is ideal, but using any waterproof electrical connector thag was support the current draw is sufficient.
I'm running the JDL shroud with the not so slim fans and have it set up this way.
Sent from my Pixel 2 using Tapatalk
JDKane527 is offline   Reply With Quote
Old 03-06-2019, 05:06 PM   #3
Hawk77FT
Drives: GTS 86
86 Speedfactory are the worst at helping out with installation of things, wiring in particular.
Hawk77FT is offline   Reply With Quote
Old 03-07-2019, 04:09 AM   #4
djezlee
Agreed! Lesson learned!
Old 03-07-2019, 04:14 AM   #5
djezlee
Great! That's a perfect solution! Is there a noticeable difference with power draw?
Old 03-07-2019, 06:59 PM   #6
JDKane527
JDKane527's Avatar
There is not a noticeable difference. Fans work and pull air through the radiator.
Old 09-03-2022, 12:16 AM   #7
Ace23_BRZ
Ace23_BRZ's Avatar
Drives: 2013 Subaru BRZ
Bringing this thread back from the dead...
So is this true?
Just asking because I am going to wire my dual SPAL fans directly into the OEM wiring myself.
Thanks in advance!
V/R,
Ace
IG - Ace23_BRZ
Ace23_BRZ is offline   Reply With Quote
Spal Fan Shroud & Koyo Radiator Carolina Dyno Forced Induction 64 12-14-2016 08:38 PM
***JDL Auto Design Low Profile SPAL Fan Shroud kit*** JDLAutoDesign Engine, Exhaust, Bolt-Ons 18 11-13-2015 11:54 AM
***JDL Auto Design Low Profile SPAL Fan Shroud kit*** JDLAutoDesign Engine, Exhaust, Bolt-Ons 74 09-03-2015 12:34 PM
Stock radiator + aftermarket Shroud to fit SPAL fans jflogerzi Forced Induction 18 09-08-2014 11:55 PM
Full Blown Stage 2, Rad + Shroud + SPAL install Ironsquid Forced Induction 3 02-11-2014 10:47 PM
