Old 07-03-2020, 12:20 AM   #1
1234eher
Drives: 2014 FRS
Angry FRS BRZ STOCK UNTOUCHED MOTOR, someone found sealent in their oil pick up mesh!
Wanted your opinions on something that I stumbled upon while doing research on preventative maintenance.
Apparently sealant was found on the mesh of the pickup tube from a 2014 frs on its stock untouched motor......
Here's the link to a youtube video if you guys wanted to take a look.
Now, this shit got me paranoid...... I'm now contemplating doing an oil pressure test and even dropping my oil pan during my next oil change......
What do you guys think about this? Any other suggestions for preventative maintenance? I already do my oil changes every 5k km
Just how many other cases are there, that we arent aware of.... could this lead to people getting rod knock? something as simple as this?
1234eher is offline   Reply With Quote
Old 07-03-2020, 01:16 AM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
Don't drink pop either:
https://www.beveragedaily.com/Articl...epsiCo-settles
Point is, there's risk everywhere. When does one stop worrying and just enjoy living?
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
JesseG (07-03-2020), thomasmryan (07-03-2020)
Old 07-03-2020, 06:35 AM   #3
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
The engine was open at some point ( during initial assembly) and there was too much sealant applied. The overhang ends up in the pickup screen. Unfortunate, but this happens.
The Following User Says Thank You to DarkPira7e For This Useful Post:
JesseG (07-03-2020)
Old 07-03-2020, 07:10 AM   #4
ToySub1946
ToySub1946's Avatar
Drives: 15FRS, 05MustangGT, 85Toyota truck
I see two problems. You are supposed to be changing oil and filter about every 12,000 km.
You are doing so too often, which will wear out the threads of the oil drain plug AND waste lots of money.
The guy in the video has the steering wheel on the wrong side of the car. Don't trust those people.
Stop worrying and simply enjoy your car...
Grab a two-four and chill is another option.
ToySub1946 is offline   Reply With Quote
The Following User Says Thank You to ToySub1946 For This Useful Post:
soundman98 (07-03-2020)
Old 07-03-2020, 08:53 AM   #5
radroach
Drives: car
This happened to a run of engines it seems early/mid production. There were a few engine failures from it.
I am surprised they didn't issue a recall on it though. At least to bring in the cars and check the oil pans. But I guess that would have open up a whole can of worms for engine replacements.
Old 07-03-2020, 09:32 AM   #6
alphasaur
friendly
Drives: 17' 86
This is one of the things I'd prefer to not think about, like how we have an orange man that can't read as POTUS.
Seek comfort in discomfort.
alphasaur is offline   Reply With Quote
The Following User Says Thank You to alphasaur For This Useful Post:
Lantanafrs2 (07-03-2020)
Old 07-03-2020, 09:45 AM   #7
Probably not enough failures reported, and the cost/benefit analysis wasn't there. My guess was they calculated it was cheaper to replace failed engines than address every one that had a small amount of sealant in the screen.
Old 07-03-2020, 12:17 PM   #8
1234eher
Drives: 2014 FRS
Is it worth dropping off the oil pan? Could this be an explanation of all the people whom has never had the engine apart experience rod knock?
Old 07-03-2020, 12:26 PM   #9
1234eher
Drives: 2014 FRS
Right, but my main concern is if this can be done as preventative maintenance, and a possible explanation for alot of blown stock motors that are well taken care of.
Or if this is even harmful at all? I'd imagine the oil filter catch these debris but then again it could clog up channels leading to it
Old 07-03-2020, 01:13 PM   #10
soundman98
soundman98's Avatar
The other side of the risk is if you drop the pan to gain access to the pickup, the pan must be resealed to the block after you're done. And poor application of the sealant there could result in the same condition.
Really, it's a horrific design to not put a manufactured gasket there...
ToySub1946 (07-03-2020)
Old 07-03-2020, 02:10 PM   #11
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
The way these engines are sealed I would not be surprised if there is a few small strands in every engine at least for a while. That amount I would not be concerned with, it's not enough to block the pickup in a significant way, and it's not like the oil pump couldn't chew that up.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
Dadhawk (07-03-2020), soundman98 (07-03-2020)
Old 07-03-2020, 10:33 PM   #12
1234eher
Drives: 2014 FRS
That is possible as well, is it worth the look though
Old 07-03-2020, 10:37 PM   #13
1234eher
Drives: 2014 FRS
The strands should be caught in the filter, but I'm worried about it causing damage on its way up there, clogging channels or damaging oil pump.
How could this even happen from the factory smh
Old 07-04-2020, 12:21 AM   #14
Grady
Grady's Avatar
OMG! That is what the screen and oil filter are for. That guy probably worries if the sun is gong to come up tomorrow.
maintanence, oil change, oil change engine damage, sealant
FS: Stock brake lines, stock clutch line, stock motor mounts Agent_D Brakes, Suspension, Chassis 4 08-22-2017 12:24 PM
AIMGAIN FB/RB/SS Kit - In Stock -- Immediate Shipping / Pick Up RavSpec Exterior Parts - The Rest 6 06-11-2015 05:09 PM
Time to build a motor, what options have others found? Cross Forced Induction 188 11-25-2014 10:10 AM
TOM's LED Tailight For FRS/BRZ ---- In Stock (Pick up or ship) RavSpec Exterior Parts - Lighting 86 07-23-2014 12:49 PM
