Old 08-08-2012, 08:40 PM   #1
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
Forza 4 FRS Tuning Discussion (GRIP)!
I want this thread to be an open forum for tuning the FRS for open lobby racing in Forza 4. I'm by far no tuning master so I am hoping I can get some help!
Right now I have been playing around with some B500 builds and I can't get the balance I want between tire width and weight. Generally speaking I drive light handling cars over heavy power cars in the game but I've not been happy with what I have come up with for the FRS so far.
With the full race weight I wound up on 235F and 245R on race compound. At this weight I couldn't go square because that put me at 502PI. Adding in cage/stiffening is trick too because it increases PI a few but seems to drastically effect acceleration! With the tires fully maxed (275) I wound up at almost 2,600lbs.
SPRING RATES! I'm at a loss here. I have a NC Miata B500 build that I love to drive and I can't seem to replicate this with the FRS. Generally I've had good luck with a decently stiffer front spring that rear but on high speed/flat corners the ass end wants to turn soooo much faster. My car still wants to push in and be loose off.
So yeah I guess I'm looking for some of you Forza tuners out there to step up and help me make my FRS go faster!!!
The Following 2 Users Say Thank You to BlaineWasHere For This Useful Post:
Allch Chcar (08-08-2012), Guff (08-10-2012)
Old 08-08-2012, 09:03 PM   #2
Allch Chcar
Drives: N/A
I try to run a bit softer rear springs than the % weight distribution. Right now I'm running 750/670, which is 52.8% front bias, and it seems pretty neutral with the sport weight reduction. I turned the rear rebound and dampers way down, half a point each. Way too much oversteer stock for a grip setup.
@bneale found it's better to run wider tires for stability than stickier rubber. It's slower but more stable.
I try to keep it square for tires, same front to back width. I'm not a pro, this is some of the stuff I've picked up.:happy0180:
-Allch Chcar
Daily Driver, occasional weekend drifter.
Allch Chcar is offline   Reply With Quote
Old 08-08-2012, 09:14 PM   #3
BlaineWasHere
Grip>Drift
Drives: FRS
I've been running similar spring rates, maybe a touch softer in the rear.
I find that the stock rebound/dampening is always very high on Forza so I've dropped those values a decent amount with a slightly softer rear end. I also have a stiffer front sway than rear, this by a decent margin actaully. Both settings here are again much softer than stock though. When you add the race sways it makes them VERY stiff.
I can get full 275 race comp on the car in B500, but it's just pretty heavy (which kills acceleration).
Old 08-08-2012, 10:08 PM   #4
BlaineWasHere
Grip>Drift
Drives: FRS
So I ended up taking on the wider tires and added weight. The car is much more stable. Corner speeds are similar but I am getting on the throttle WAY WAY sooner which is good but straight line speeds did suffer.
I wound up with 6.5 for handling and Accel. I was also able to achieve this with 245s and race weight but it's not as stable.
This is DEF not going to be a leader board car, but I'm thankful for that.
Old 08-08-2012, 10:32 PM   #5
bimmerboy
Drives: 2009 135i
idk about anyone else but i love the car completely stock. Really fun to drive even if its a little slow. A good testament to how good the car is stock in real life IMO
bimmerboy is offline   Reply With Quote
Old 08-08-2012, 10:38 PM   #6
Asterisked Accolade
Pedals over Paddles.
Asterisked Accolade's Avatar
Drives: Celica GT-S | 89 Supra | 07' Accent
I never make drift cars, i only focus on Grip. I've gotten very good at tuning my cars to retain grip and have good turn-in. But it'd be a long post it i checked and posted all my tuning numbers.
2002 Celica GT-S Track Car | 1989 Supra Track Car | 2007 Hyundai Accent AutoX | 2003 Cadillac CTS Daily
Asterisked Accolade is offline   Reply With Quote
Old 08-08-2012, 10:51 PM   #7
CSSM
Still Dreamin'
CSSM's Avatar
Drives: 2001 Chevrolet Tahoe
And this is why your B class FR-S owned mine
I try to make my tunings realistic for a real life budget so mine suck haha
CSSM is offline   Reply With Quote
Old 08-08-2012, 10:56 PM   #8
Spaceywilly
ZC6A2B82KC7J
Spaceywilly's Avatar
Drives: 2002 WRX
Just set a top 2% time with my c class frs on stock tires. It's all about light weight with this car.
Straights are for fast cars. Turns are for fast drivers.
Spaceywilly is offline   Reply With Quote
Old 08-08-2012, 11:17 PM   #9
BlaineWasHere
Grip>Drift
Drives: FRS
I went back and made another B build for R comp and lightness and wound up at 2295lbs
Old 08-10-2012, 06:46 PM   #10
BlaineWasHere
Grip>Drift
Drives: FRS
btt
Old 12-12-2013, 05:35 PM   #11
FReSh
Dirt Trackin'
FReSh's Avatar
Drives: '13 Raven FR-S MT
I've spent a pretty good amount of time on my B500 FR-S in Forza. I'll post up the stats so you guys can try it out and let me know what ya think! This car is a bit more on the speed side compared to the builds you guys were talking about, but I think it is pretty stable and can be very fast in the corners if you have reasonable throttle control.
Parts:
Street Air Filter
Race Fuel System
Sport Ignition
Race Brakes
Race Springs and Dampers
Sport Weight Reduction
Street Tire Compound
245/40/17 Front Tires
245/40/17 Rear Tires
Dymag 9 spoke wheels
That should put the car at 2497 lbs with 245hp and 185 lb/ft torque at B500.
Set-up:
Tires: 34psi front, 33psi rear
Gearing: Stock (Unadjustable)
Alignment: -.08 Camber (F+R), 0 toe (F+R), 5.0 Caster
Anti-Roll: Stock (unadjustable)
Springs: 654 F, 554 R, 4.9" ride height F+R
Damping: 8.0 F 8.4 R (rebound), 7.9 F 5.6R (Bump)
Aero: Stock (Unadjustable)
Braking: 52% Front, 98% Pressure
Differential: Stock (Unadjustable)
I generally drive with ABS on, TCS off, STM off, and manual with clutch.
Let me know what you guys think about that set-up
FReSh is offline   Reply With Quote
The Following User Says Thank You to FReSh For This Useful Post:
cfusionpm (12-13-2013)
Old 12-12-2013, 07:07 PM   #12
cfusionpm
Drives: Firestorm 6MT Scion FR-S
I'll have to use some tips for mine.... It can't seem to stop sliding its rear end around no matter what I do.
2013 Firestorm 6MT Scion FR-S
cfusionpm is offline   Reply With Quote
Old 12-14-2013, 09:46 AM   #13
FReSh
Dirt Trackin'
FReSh's Avatar
Soften the rear springs.
Old 12-14-2013, 01:48 PM   #14
cfusionpm
I copied your design step for step on the suspension (because I know nothing about suspension setups) and it gives me a good base to work off of. The last two Forza games I played I started with FWD or AWD until I got something like a Ferrari F430 or 458, and those were good to go without much more than a sway bar and slightly tweaked LSD. This has a much more balanced feel than stock for the FRS, but I cranked the brakes way up because I'm a really aggressive late braker when starting at the back of the pack. Thanks for the help!
The Following User Says Thank You to cfusionpm For This Useful Post:
FReSh (12-15-2013)
Let's get tuning! EcuTek tuning now available! carbonBLUE Southwest 6 06-29-2015 02:37 PM
ESBJIUJITSU's FRS DD GRIP MACHINE WISH LIST ESBjiujitsu Member's Car Journals 8 05-16-2012 11:41 AM
The grip dilemma - tires swift996 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 03-23-2012 11:35 PM
more grip? aesthetect Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 45 12-19-2011 10:51 PM
Forza 3 vs. GT5 Discussion Thread Snaps Off-Topic Lounge [WARNING: NO POLITICS] 386 03-06-2011 12:10 AM
