Old 08-08-2012, 08:35 PM   #1
twincamRob
twincamRob's Avatar
Drives: 2013 FS FR-S
Muffler delete pipe = extreme temps at tailpipe??
Robbie S.
-13 FR-S
-12 H-D 48
Instagram: @twincamrob
twincamRob is offline   Reply With Quote
Old 08-08-2012, 08:58 PM   #2
mike2100
mike2100's Avatar
Drives: 23 BRZ
Weird indeed. It looks like your tip extends out even further than the stock tips, which would rule out the extra heat coming from exhaust gasses exiting the pipe.
What type of metal did you use? I wonder if it holds more heat than the stock exhaust's metal, or that used by typical aftermarket companies.
mike2100 is offline   Reply With Quote
Old 08-08-2012, 09:28 PM   #3
xjohnx
Grip>Slip
xjohnx's Avatar
it's definitely hot. apparently this was after 120 seconds of axleback delete with no straightpipe
Old 08-08-2012, 09:35 PM   #4
ayau
Drives: Some rust bucket
yeah, i guess it's not surprising to see higher temps from a simple straight pipe.
the stock muffler is basically a giant heatsink. larger surface area = heat is spread out more.
making the pipe longer (increase surface area) and aiming it downward might help in saving your bumper.
Old 08-08-2012, 09:39 PM   #5
mike2100
mike2100's Avatar
Drives: 23 BRZ
time to break out the header wrap?
Old 08-08-2012, 09:41 PM   #6
ayau
that would just increase the temps even more because you're trapping the heat.
Old 08-08-2012, 09:42 PM   #7
xjohnx
Grip>Slip
xjohnx's Avatar
i'd just weld up some longer exhaust hangers.
Old 08-08-2012, 09:44 PM   #8
mike2100
mike2100's Avatar
Drives: 23 BRZ
Well you could insulate the tip from the bumper at least. It would look funny
Old 08-08-2012, 09:47 PM   #9
serialk11r
Drives: '06 AM V8V Coupe
Could be an aerodynamics thing. You're injecting exhaust gas into the wake of the car, so it's expected that it could come around and linger around the bumper. Removing the muffler interferes with the airflow under the car too, and that could be causing more heat to reach the bumper too.
Seems very unlikely that the heat is getting there via radiation off the pipe, so maybe try extending the pipe an inch or two, and attaching a piece of coroplast or something to the bottom as a temporary diffuser.
Old 08-08-2012, 10:10 PM   #10
d1ck
Drives: Black 2013 FRS
Try putting on an exhaust tip, they act as a heat shield.
d1ck is offline   Reply With Quote
Old 08-08-2012, 10:36 PM   #11
bimmerboy
Drives: 2009 135i
wow seems like that high compression really affects EGTs... I would maybe use a larger diameter pipe and angle it down so the exhaust is flowing away from your bumper..
bimmerboy is offline   Reply With Quote
Old 08-09-2012, 12:32 AM   #12
simpleisbest
Senior Citizen
Drives: Scion FR-S
I have the Nameless exhaust delete installed. No problems so far.
I think it extends a bit further out than the one you made.
simpleisbest is offline   Reply With Quote
Old 08-09-2012, 01:05 AM   #13
Reason
Reason's Avatar
Drives: Whiteout 6MT FR-S; E30 BMW's
To apply Occums Razor on both points
The steel you're using might be radiating more heat than the stock pieces (and as mentioned, would be less of a heat sink with far less surface area, too)
For the paint;t your can of paint has either gone bad, or reacted in a way it normally wouldn't.
Thats just my theory.
Reason is offline   Reply With Quote
Old 08-09-2012, 02:16 AM   #14
Xanatos
Xanatos's Avatar
Drives: @redline, '14 BRZ, '98 Forester
Boy you'll be spitting some flames with this!
I have a feeling this has to do with pressure/flow. With the stock exhaust you have two outlets so the heat from your exhaust is spread out and you cut the exhaust flow in half. I don't know if you still have enough scrap but I would try a whole new tailpipe with a 2nd outlet on the other side like stock.
That's my guess at least. Toyota/Subaru spent all this time developing a lightweight car I would think they would have removed a 2nd exhaust if they could get away with it.
Xanatos is offline   Reply With Quote
Mach V muffler delete prototype Mach V Dan Engine, Exhaust, Transmission 118 02-01-2013 07:41 AM
Resonator delete? Sound with stock muffler? Nate219BRZ Engine, Exhaust, Transmission 23 09-05-2012 06:42 PM
Custom Muffler Delete w/ Videos! IceCreamMan Engine, Exhaust, Transmission 5 06-28-2012 07:12 PM
X-Pipe with Muffler delete dav0777x Engine, Exhaust, Transmission 3 06-21-2012 10:30 AM
