Old 06-19-2020, 10:54 PM   #1
majixmatrix
BRZ Wannabee
majixmatrix's Avatar
Drives: 2013 Limited BRZ
Perrin Gurney Flap, OEM BRZ DRL & LED Blinkers
I have the following lighting parts for sale:
- Perrin gurney flap which is used but in good condition; will not include hardware but you can find what you need: $70
- LED blinker lights for front headlight, these are incredibly bright: $20
- Pair of OEM BRZ daytime running lights (above fogs), have been converted to use spade connectors: $100
If you're interested in anything else in the full part out picture, please reach out for the following:
- Manual steering wheel with custom katana ito wrap has held up well to 30k miles: $100
- Lightweight Perrin water pump pulley. Used condition, has a bit of gold overspray on it that can be removed. Significantly lighter than stock: $60
- OEM coil packs that ran fine on the car for 70K miles: $80
- Hawk Street 5.0 brake pads with only 50 miles on them!: $180
- Dragonball shift knob for automatic shifter: $10
- ATEQ QuickSet TPMS programmer, super easy to use for changing summer & tire wheels: $100
- Planted seat bracket, used and in good condition: $100
Last edited by majixmatrix; 06-19-2020 at 11:03 PM. Reason: Forgot to add gurney flap to title, listing, & pic
majixmatrix is offline   Reply With Quote
Old 09-05-2020, 06:07 PM   #2
ENVJFRSH
Drives: 2013 Scion FRS
Whats up boss could i get the bulbs you have thats oj the white paper
ENVJFRSH is offline   Reply With Quote
blinker, brz, drl, led, oem
DIY side marker blinkers boonFRS DIY (Do-It-Yourself) Guides 112 06-08-2020 02:45 AM
Blinkers not working Carlitoz3 Electronics | Audio | NAV | Infotainment 6 04-25-2019 02:01 AM
LED side markers cause dim blinkers rileymcmuffins Issues | Warranty | Recalls / TSB 0 07-29-2015 12:53 AM
I just got these Smoked Taillights on Ebay! Blinkers All Messed Up! HELP! HueyLooie Cosmetic Modification (Interior/Exterior/Lighting) 7 02-11-2015 10:53 PM
black housing blinkers lbroskee Cosmetic Modification (Interior/Exterior/Lighting) 9 09-02-2012 05:07 AM
