Old 06-18-2020, 06:53 PM   #1
zero_limits
Drives: Subaru BRZ 2017 PP
Do I need aftermarket bolts to install an uel header?
Hi,
I just bought a used uel ft86 catted header, along with a pair of new grimspeed gaskets.
I currently have the stock overpipe, will I need any additional hardware such as additional/different bolts to mount the new header? or can I reuse the original bolts that connect the header to the overpipe when installing the new header?
Thank you!
zero_limits is offline   Reply With Quote
Old 06-18-2020, 06:55 PM   #2
Howaitoguru
Howaitoguru's Avatar
Drives: 2016 Subaru BRZ
Originally Posted by zero_limits View Post
Hi,
Thank you!
I would just go ahead and go to fastenal and get some new ones if I were you. You don’t have to but why not.
Howaitoguru is offline   Reply With Quote
Old 06-18-2020, 06:56 PM   #3
Ashikabi
Ashikabi's Avatar
Hi,
Thank you!
You'll need new bolts
Old 06-18-2020, 07:12 PM   #4
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
You don’t. I’ve had my header off 3 times and still on stock nuts. Just make sure they’re not chewed up and the thread is smooth and clean.
Old 06-18-2020, 07:13 PM   #5
86MLR
86MLR's Avatar
I used the same OEM nuts and swapped out the header about 5 times.
Last time also had a turbo manifold hanging off it.
If you use a torque wrench and tighten the nuts up properly you wont need new ones.
http://www.ft86club.com/forums/showthread.php?t=133311
I'm only here for the biscuits
what are these 2 bolts I got in my ace header box? Breadman DIY (Do-It-Yourself) Guides 6 05-21-2018 11:23 AM
OEM exhaust manifold gaskets ok for aftermarket header install? giorgi0424 Engine, Exhaust, Transmission 3 02-22-2017 10:43 AM
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? alanhung85 CANADA 6 10-21-2014 10:41 PM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 04:12 PM
Aftermarket camber bolts safe? was385 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 04-19-2013 11:30 AM
