Drives: FRS
Would any on here happen to know what the stock FRS brake bias is, and would anyone happen to know what the optimal bias would be for street use/daily driver.
Does anyone happen to know where to find the brake bias online, I’m sure it’s around somewhere, and seeing that the rear brake is smaller I assume it’s considered front bias on stock. |
Drives: Crapcan
Just an FYI, but it you post easy to google questions on the regular you are going to get a fair amount of flack around here. Bias info is in this link.
https://www.pointmeby.com/2016/09/24...z-frs-gt86-86/ Close to stock is best as it is what the factory ABS is designed around.
Drives: Legacy GT
That guy's piston size numbers are wrong for the stock front caliper as are his effective radius numbers so that whole chart has some issues.
I have what I think is a slightly better one. My numbers for stock brakes are about 65:35. With EBD, it is less relevant. They system adjusts front and rear pressures based on wheelspeed, before a more traditional ABS would need to intervene to prevent lockup. |
| The Following User Says Thank You to jamal For This Useful Post: | NoHaveMSG (06-18-2020) |
Drives: 2014 GT86
Default EBD is rather understeer biased and makes a bit harder to trail brake and also comes "in package" of eg. e-diff. Thus many on track do pedal dance leaving only basic ABS, and so base EBD-less bias may matter more.
| Brake bias regulating for drifting | Maarten | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 13 | 09-13-2017 03:49 AM |
| brake bias for cadillac caliper swap and other BBKs | sickmint79 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 39 | 09-26-2016 03:03 PM |
| Brake Bias & Proportioning - Shop Car Update | Carolina Dyno | Tracking / Autocross / HPDE / Drifting | 10 | 11-07-2015 02:52 PM |
| Brake bias calculations for BBK | Fizz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 29 | 09-08-2015 01:50 PM |
| CHP bias | ndsleep612 | Northern California | 11 | 07-28-2013 11:05 PM |
