Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > NY / NJ / CT / PA
NY / NJ / CT / PA NY, NJ, CT, PA
Old 06-17-2020, 01:02 PM   #1
Formula Vee
Lando.Ricciardo.Hamilton.
Formula Vee's Avatar
Drives: 2014 SWP BRZ Limited (MT)
Aftermarket suspension installer near central NJ?
Hi, gang! I'm looking to maybe upgrade the springs on my BRZ now that I have stickier rubber. Specifically looking at this:
https://www.ft86speedfactory.com/rce...l#.XupMBi2z3OQ
I don't have the space, tools, or ability to do that myself. Can anyone recommend a good aftermarket installer in NJ, ideally central? I'm in the Edison/New Brunswick area.
Many thanks!
OFT Stage 1 -- Grimmspeed Strut Tower Bar -- Perrin Inlet Tube -- K&N Engine Filter
Formula Vee is offline   Reply With Quote
Old 06-18-2020, 12:17 AM   #2
cnk
Drives: '13 DGM BRZ Limited
AZP in Kenilworth or Precision Tuning in Spotswood.
cnk is offline   Reply With Quote
Old 06-18-2020, 06:39 AM   #3
Tanstin
Tanstin's Avatar
Drives: 2013 Scion FRS
Does the RCE starter kit use the RCE yellows or is that a completely different lowering spring model?
I was comparing photos between that kit and the regular yellows and i noticed the standalone version had "Z/P" below the BRZR tag on the rear springs. They otherwise look identical
Tanstin is offline   Reply With Quote
Old 06-18-2020, 10:33 AM   #4
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
Yes it uses RCE yellow lowering springs. Though I have not firmly looked at photos, I know there is only one set of these springs made with that name, the price is right, and the kit does specify that these springs come with it.
Dzmitry is offline   Reply With Quote
Old 06-18-2020, 10:54 AM   #5
Formula Vee
Thank you, cnk! Spotswood is a short drive away. Much appreciated.
Old 06-24-2020, 09:15 AM   #6
KAR
Drives: Whiteout 6spd
Straight line automotive is in Matawan..
KAR is offline   Reply With Quote
FS: Various Suspension Parts Aftermarket/OEM Katsu Brakes, Suspension, Chassis 16 11-09-2020 10:42 AM
WTB: Aftermarket Tail Lights - Central KY RedFR-s Want-To-Buy Requests 0 01-16-2017 03:06 PM
Aftermarket suspension making handling worse? RaceR Suspension | Chassis | Brakes -- Sponsored by 949 Racing 82 07-24-2014 10:39 AM
Aftermarket wheels with stock suspension Thongpocket Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 01-24-2013 05:08 PM
